- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
Patrick_
I have a question but I'm almost positive I know the answer.
I have a ton of procedures in a row. Now, when a user clicks a button, the procedures are initiated and executed. Before they do though, the the procedure that was called from the button, it checks to see if a setting is checked. If so, it continues. If not, it does the next procedure in the button call.
Now, I think that is very slow. Wouldn't it be much faster to check if the setting is checked BEFORE to procedure is executed?
https://www.neowin.net/forum/topic/283007-vbnet-speed-question/Share on other sites
5 answers to this question
