Right click on start menu not working
hi, i am using wxp pro sp2, and yesterday all of a sudden right clicking on the start menu stopped working! it is working everywhere except on the start menu, you know the one where i have the option to pin something or sort order in the all programs section, when i right click there just nothing happens. that's really weird, and for now i have to use the classic view, but i don't like it and there must be a solution to this.
i scanned and found no viruses or spyware, what could it be?
Hmmm... If that doesn't work then I'm afraid it could be a virus or some nasty program disabling right click - I'm not sure. That tool repairs the registry DWORD value so that you can right click again - so it can't be a registry problem I don't think. Sorry, I can't really help.
Oh and @Bold_Fortune: Thanks, it's a good tool. Glad you like it as well as I :D
  dreamz said:
you have to check it.
585488076[/snapback]
Sorry, I checked it as well. :blush:
Didn't work. :(
@saiz66: That's OK :) The function you mean, is that you can't drag files and shortcuts into the start menu/taskbar. He can't right click on the start menu at all. The only way I know how to disable right click on the start menu is by registry.
But kolp has tried that using the taskbar tool.
