Help with Counterstrike Source Aspect Ratio
Hey all :)
I was playing Counterstrike Source today, and I was changing around some of the settings.
Went into video, and changed the aspect ratio to 16:10 (The second widescreen ratio that it shows).
The only thing is, this isn't a mode my monitor can support, so I can no longer play the game as the monitor is black and has a dialog telling me it doesn't support the aspect ratio the game is in.
I tried reinstalling the game but that hasn't fixed the problem.
I was wondering however, is there anything I can add into like the counterstrike source config to make the game play in the normal 4:3 ratio?
I don't want to have to guess my way through the menu system or buy a new monitor for it :(
Can anyone shed some light for me please? :blush:
All help is appreciated, thanks alot
Stu
Here is a link on steampowered.com support page that will force reset your video settings.
http://steampowered.custhelp.com/cgi-bin/s...li=&p_topview=1
Force Video Mode Reset
You might still get into a situation where you still have problems though, so as an option, you can force Steam to re-detect and re-configure your video settings.
Basically all you need to do click on one of these links, depending on which game you are having problems with.
