JoDaddy Posted May 18, 2005 Share Posted May 18, 2005 I know that control userpasswords2 will get you to the other user names and passwords control panel, but is there a run command to get to the advanced users and groups panel? I normally have to run control userpasswords2, then click on the Advanced tab, then click on the advanced button to get there. A screen is below. Link to comment https://www.neowin.net/forum/topic/321953-command-for-advanced-users-panel/ Share on other sites More sharing options...
Herby Posted May 18, 2005 Share Posted May 18, 2005 This is the exact command from the Advanced Button: mmc.exe C:\Windows\System32\lusrmgr.msc computername=localmachine Link to comment https://www.neowin.net/forum/topic/321953-command-for-advanced-users-panel/#findComment-585939520 Share on other sites More sharing options...
bfoos Posted May 18, 2005 Share Posted May 18, 2005 lusrmgr.msc is what your after. Link to comment https://www.neowin.net/forum/topic/321953-command-for-advanced-users-panel/#findComment-585939539 Share on other sites More sharing options...
JoDaddy Posted May 19, 2005 Author Share Posted May 19, 2005 thanks, guys! Link to comment https://www.neowin.net/forum/topic/321953-command-for-advanced-users-panel/#findComment-585942397 Share on other sites More sharing options...
