[Ubuntu 5.04] Various problems and questions
I installed Ubuntu 5.04 yesterday and have quite a few problems, which I hope someone here might help me solve. Here's the most important of them:
1. Internet Connection
My ADSL modem (the Thomson SpeedTouch 330) is known to be difficult to install and for me has been completely impossible. I've found a lot of guides on this subject but none of them has been comprehensive enough for a complete n00b like myself.
2. Sound Card
The soundcard is integrated into the mainboard, it's a CMedia CMI9761. The system seems to recognize it properly and it is displayed in the volume settings but no sound is coming from the speakers.
My setup:
AMD Sempron 2400+
ASRock K7 Upgrade 880 (Via KT880) - http://www.asrock.com/product/product_k7upgrade880.htm
512MB RAM
nVidia GeForce2 GTS
Thanks for your help!
Can't help with the modem, but regarding the sound: if it was detected, it _should_ work. Which means, it's probably muted (Linux always sets the volume for all channels to 0 by default, to protect your speakers and your ears). Open a terminal and start "alsamixer". After you're done with the settings, become root and enter "alsactl store", this should ensure that your settings stay that way after a restart...
Mabye someone can help me understand why there are drivers for modems?
I have sbc yahoo dsl. I plug the net connection into the modem and then have an ethernet cable going to the router and I setup linux on dhcp? Why does modem drives need to be installed? What do they do? Sorry for not understanding mabye someone can clear this up for me :)
586037884[/snapback]
Some people have modems that don't have ethernet connections, and the only possible way to connect them is to a USB port. Mine, also a Thomson(nee alcatel) speedtouch 330, is one of them. The only way to connect it is via a usb port to a PC, and the PC will obviously need drivers for it.
About getting the speedtouch to work: Try http://speedtouchconf.sourceforge.net/. If that doesn't work for you, I can provide a tarball of the files which I used to use on Ubuntu 5.04, all you'll need to do is extract the tarball to a directory and run a script inside it to connect.
586039305[/snapback]
I tried speedtouchconf but to no avail. I would be very grateful if you could provide me with such a tarball.
Thanks!
Thanks!
586039467[/snapback]
Do you know what revision your speedtouch is? I have the files for a rev 4 model, but if you have an older revision I'll need to grab some alternative firmware...
The rev 4 model is silver coloured, and a sort of flattened round-ish shape... (a silver version of the attached). What colour is yours?
ahh ok thanks I have usb port on my modem but never played with it
