- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
$phinX
Im building a WinForms application and I have a DataGrid that is populated by binding to a DataTable. I want to be able to highlight the edits made in the DataGrid in red forecolour - so the user can easily see the changes that are waiting to be written to DB.
I have currently implemented this by creating a new column style class that inherits from DataGridTextBoxColumn and then overrides the Paint(...) method. I declare all the DataGrid columns to be of this column style (which messes up the DataGrid layout settings). Then whenever the user makes an edit i have to prefix it with square bracket so it knows its an edited cell and sets the forecolor red.
I dont really like this method... is there no simpler way to just show which cells have been edited... please advise... thx.
https://www.neowin.net/forum/topic/346207-c-winforms-datagrid-help/Share on other sites
6 answers to this question
