Tran Posted July 19, 2005 Share Posted July 19, 2005 I was playing with my HUD for a bit, installing new ones and trying them out, but when I tried to revert back to the default HUD, this is what I get (posted below). Can anyone help me get it back to normal? Link to comment https://www.neowin.net/forum/topic/346315-counter-strike-source-hud-problem/ Share on other sites More sharing options...
w33zy Posted July 19, 2005 Share Posted July 19, 2005 look @ www.csbanana.com they got an hud program u can move the numbers to a better place. heres mine hud :EDIT to remove uhm delete Valve/Steamapps/(Email)Counterstrike source/Cstrike/scripts/ Delete HudLayOut And Script Link to comment https://www.neowin.net/forum/topic/346315-counter-strike-source-hud-problem/#findComment-586237488 Share on other sites More sharing options...
Tran Posted July 19, 2005 Author Share Posted July 19, 2005 Not sure if it's worth mentioning, but I found a solution to my problem! :D All I did was just delete all the fonts that came with the previous HUDs I used. Now it's all fixed! Yay! Now I can play CS:S again (and not be annoyed). Link to comment https://www.neowin.net/forum/topic/346315-counter-strike-source-hud-problem/#findComment-586239210 Share on other sites More sharing options...
