Problem with UXTheme Multi-Patcher.....
I get this message when I tried to run the patcher:
"Neowin UXTheme Multi-Patcher v4.0 has detected that there's any Windows NT setup file in C:\windows\
It's not recommend you to continue with this. Please eject your Windows NT CD or move your setup files to other path. Press OK to exit patch."
:wacko: Help?
https://www.neowin.net/forum/topic/357102-problem-with-uxtheme-multi-patcher/
I suppose the version 4 is made especially for XP2/64 or what have you? Manually is probably one way to go, but i just reached back and applied the NeoWin 2.1.5 patcher and it works perfectly on my XP Pro SP1.
Still don't care for SP2 and never will, no real security diff anyway like M$ wants everyone to believe plus look at all the hassle surrounding it in and out of Moddings. Plus the Bluetooth stack is really lame when you get into needing to pair another device (driver conflicts etc.)
Just wanted to mention not everyone has a bad experience with the Patcher, in my case the older version was the first choice. Thanks for putting it together.
