Help removing VBS scripts
I installed these VBS shortcuts, and now I'm wondering how to uninstall them. If I delete them from my desktop, all it does is hide them. I use the Desktop Toolbar, and they're still in that menu. Would someone be willing to take a peek at these scripts and maybe write one that will unregister them? Thanks.
https://www.neowin.net/forum/topic/364100-help-removing-vbs-scripts/
3 answers to this question
Open the script file. There are lines like this:
WShell.RegWrite PROD_CLSID & "Shell\Open\command\", PROD_EXE, "REG_SZ"
What you do is go to the registry at: PROD_CLSID & "Shell\Open\command\"
Which, when expanded, becomes: HKCR\CLSID\{EC8030F7-C20A-464F-9B0E-13A3A9E97384}\Shell\Open\command
PROD_EXE is whatever data you need to delete.
Edit:
Actually, you can just delete these keys: HKCR\CLSID\{EC8030F7-C20A-464F-9B0E-13A3A9E97384}
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel\{EC8030F7-C20A-464F-9B0E-13A3A9E97384}
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\ClassicStartMenu\{EC8030F7-C20A-464F-9B0E-13A3A9E97384}
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace\{EC8030F7-C20A-464F-9B0E-13A3A9E97384}
Edited by Post-It Note
Thanks! I found those entries and deleted them, and now I can actually delete them from the Desktop Toolbar menu.
EDIT:
More specifically, I found the corresponding entry
(that's just Firefox) for Thunderbird & Sunbird and deleted those. Then I just deleted the shortcuts from the Desktop Toolbar menu, and they're gone.
Edited by Yochanan
