- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
mattmatik
Ok, I was reading some posts about BF2 and someone said they kill their explorer using ctrl+alt+del and then running the game to get extra resources. It works fine but I was wondering if there is a way I can add an argument to the bf2.exe so it does this automatically?
I have a dock, konfabulator, and some other programs I use constantly...is it possible to include an argument that can kill those as well? Thanks :)
https://www.neowin.net/forum/topic/364754-how-to-kill-explorer-when-running-program/Share on other sites
13 answers to this question
