Here is a list of things to do:
1) Enable WPA-PSK using TKIP encryption. - This gives you the best access control for a home setup. Make sure your clients support this otherwise you must use WEP. You password protect your AP so a password must be entered to connect. I reccomend using a passphrase of at least 20 characters including numbers and symbols.
2) Enable MAC filtering and add your wireless computers to the trusted list.
3) Change your SSID to not default. Also you may consider turning off the broadcasting of the SSID.
    • I don't think RTSS can show the real framerate. In fact, this is the first time I have ever heard about anything showing it.
    • Yeah, Deck's overlay has CPU temps. Maybe they don't want to rely on external dlls to provide CPU temperature graphs on all machines? From my experience with Rivatuner it can be annoying to select the correct CPU temperature sensor.
    • Why would I be praising Microsoft? You do realize I'm well aware the Gamebar is a stinking pile of crap and has been for years, right? Or are you one of those "if you don't critique something at every turn you area clearly a fanboy" people? Yes, MangoHUD is built into SteamOS's Big Picture mode, and up until a few weeks ago, SteamOS was exclusive to... the Steam Deck... for 3 years. Yet you were talking about it as if you didn't need to set it up yourself, like it was built into other distributions, which it wasn't. So if we ignore the real/fake framerate feature, it's really not much different than me setting up my Rivatuner/HWInfo overlay, is it? Valve had the option of building MangoHUD into Steam, like they are doing it now, for 3 years. So let's not pretend Windows hasn't had a basic way to display your framerate built in, keeping well aware how crap it actually is. And I'm not even counting your GPU driver company, because Nvidia, AMD and Intel have their own (somehow even worse than GameBar) overlays. And of course they won't tell you fake/real framerate, why would Nvidia nor AMD want to tell you? That is absolutely a +1 on Valve.
    • As much as I like the push towards Wayland (is Gnome still bickering about window decorations and "you are doing it wrong"ing rest of the industry?) but as an admin, the fact that the FreeRDP (because VNC is dead) implementation is not functional yet is really annoying, as that is what RHEL10, and Debian13, will be stuck with for the next 3-8 years.
    • qBittorrent 5.1.1 by Razvan Serea The qBittorrent project aims to provide a Free Software alternative to µtorrent. qBittorrent is an advanced and multi-platform BitTorrent client with a nice user interface as well as a Web UI for remote control and an integrated search engine. qBittorrent aims to meet the needs of most users while using as little CPU and memory as possible. qBittorrent is a truly Open Source project, and as such, anyone can and should contribute to it. qBittorrent features: Polished µTorrent-like User Interface Well-integrated and extensible Search Engine Simultaneous search in most famous BitTorrent search sites Per-category-specific search requests (e.g. Books, Music, Movies) All Bittorrent extensions DHT, Peer Exchange, Full encryption, Magnet/BitComet URIs, ... Remote control through a Web user interface Nearly identical to the regular UI, all in Ajax Advanced control over trackers, peers and torrents Torrents queueing and prioritizing Torrent content selection and prioritizing UPnP / NAT-PMP port forwarding support Available in ~25 languages (Unicode support) Torrent creation tool Advanced RSS support with download filters (inc. regex) Bandwidth scheduler IP Filtering (eMule and PeerGuardian compatible) IPv6 compliant Available on most platforms: Linux, Mac OS X, Windows, OS/2, FreeBSD qBittorrent 5.1.1 changelog: BUGFIX: Don't interpret wildcard pattern as filepath globbing (glassez) BUGFIX: Fix appearance of search history length spinbox (glassez) BUGFIX: Remove dubious seeding time max value (glassez) BUGFIX: Fix ratio handling (glassez) BUGFIX: Fix compilation with Qt 6.6.0 (glassez) WEBUI: Make General tab text selectable by default (dezza) WEBUI: Add versioning to local preferences (Chocobo1) WEBUI: Make multi-rename search & replace fields use a monospace font (Atk) WEBUI: Fix wrong replacement sequence in IPv6 string (Chocobo1) WEBUI: Fix memory leak (bolshoytoster) WEBUI: Fix path autofill in set location and new category (tehcneko) RSS: Mark matched article as "read" if it refers to a duplicate torrent (glassez) WINDOWS: Update command line help message (KanishkaHalder1771) WINDOWS: NSIS: Don't require agreement on the license page (Chocobo1) LINUX: Fix preview not opening on Wayland (Isak05) LINUX: Add fallback for random number generator (Chocobo1) Download: qBittorrent 5.1.1 | Portable | ~40.0 MB (Open Source) Download: qBittorrent 64-bit installer (qt6) | 41.7 MB Links: qBittorrent Home page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      urbanmopdubai1 earned a badge
      Jim Dugan earned a badge
      viraltui earned a badge
      serfegyed earned a badge
      145
