- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
timsweb
Hey,
ok, well basically, its only a small thing but, it shows fine in firefox, but not ie (6 & 7)
Heres the code for you to test:
And here is the image it needs (box.png):
As you see it shows fine in firefox, nice and smooth gradient, but in IE, it dosent, lol, why? and how do i fix it?
Thanks, Tim
https://www.neowin.net/forum/topic/373535-htmlcss-ie-problem-works-fine-in-firefox/Share on other sites
2 answers to this question
