system32 config error HELP!
I am on my old computer but when i turn on my new computer it shows the intel screen, then comes to like a boot menu saying system32/config/ is missing/ corrupt
i have trying opening in safe mode, i have tried last configuartion, basically everything, i put my disk in and what not still nothing
NOTE: i cant even get to my login screen so please dont reccomend anything that consist of start menu.... etc
HELP PLEASE!!!!!
i dont want to have to reformat, and even so idk how i would, it wont let me do anything!
HELP
https://www.neowin.net/forum/topic/374919-system32-config-error-help/
How to troubleshoot registry corruption issues
http://support.microsoft.com/default.aspx?...kb;en-us;822705
How to recover from a corrupted registry that prevents Windows XP from starting
http://support.microsoft.com/default.aspx?...kb;en-us;307545
must have the XP CD to get to recovery console
There has to be something after "\config". Assuming the corrupt hive is the "system" hive, you would do the following:
Boot to the XP CD and select R (Recovery Console)
At the command prompt type:
ren c:\windows\system32\config\system system.old
copy c:\windows\repair\system c:\windows\system32\config
Reboot
If it's another hive, just substitute it for the word "system"
i have an intel pentium 4 3.0ghz processor,
and an intel extreme series motherboard
how do i set it to boot to the cd?
i do the f2 thing, then im in the menu etc. but i cant find the way to set it to boot to the cd.
after i boot to the cd and once i finish this p-rocess will i need to change it back?
once in the bios, there should be a boot menu across the top. use the arrows on the keyboard to get to the boot menu. down arrow to first boot device, enter key, choose CD-ROM drive. No you dont have to change it back unless you care about the 1-2 secs it may add to your boot time
