openGL Problem
I'm having a weird problem with this star I'm drawing. When it is drawn with GL_LINE_LOOP is shows all the proper lines. But when its is drawn using GL_POLYGON it is messed up. (See Pictures Below) I have pasted in my code being used to draw it. Any help would be amazing.
Thanks.
glBegin(GL_LINE_LOOP);
glColor3ub(255,255,255);
glVertex2f(0.12,0); //bottom left
glVertex2f(0.25,0.12);
glVertex2f(0.38,0); //bottom right
glVertex2f(0.32,0.19);
glVertex2f(0.45,0.3); //middle right
glVertex2f(0.3,0.3);
glVertex2f(0.25,0.5); //top
glVertex2f(0.2,0.3);
glVertex2f(0.05,0.3); //middle left
glVertex2f(0.17,0.20);
glVertex2f(0.12,0);
glEnd();
https://www.neowin.net/forum/topic/383127-opengl-problem/
5 answers to this question
GL_POLYGON is only good for drawing convex polygons. a star is concave :)
what happens is it connects the first vertex to ALL the other vertices... so it turns out you have extra polygons :p
you should start at the middle of the star and make the "rays"
https://www.neowin.net/forum/topic/383127-opengl-problem/#findComment-586649625
  mstrmind said:
Thank you very much for the help.  I should have my star under control by later today.
Any idea why GL_POLYGON was set up for convex shapes?  Seems kinda silly to only support one type of polygon
586651429[/snapback]
Well, concave polygons are very slow to fill because you must find all places to fill in between whereas with a convex polygon it's very fast. GLU however provides routines to tessellate concave polygons into convex ones.
https://www.neowin.net/forum/topic/383127-opengl-problem/#findComment-586651798
