Graphics Problem
Well im at my grandmas and im trying to get her computer to run better.
It has had this graphics problem for quite some time now. When you go to Properties and then the color settings it doesnt even have the setting for the normal 32MB. Its only 16 colors or whatever. Its just very odd that it doesnt even have the option.
Anyway, i downloaded the same graphics driver from a 3rd party site and installed it, still no luck.
If anyone has any ideas at all that would give me the option to raise the graphics level on this computer i would be so happy :)
Any help is appriciated.
OS: Windows 98
~Anthony
https://www.neowin.net/forum/topic/384175-graphics-problem/
Sorry about that, im on my computer right now and didnt even think to get the Specs off the other before i got on this one. Here they are though:
OS: Windows 98
Processor: GenuineIntel
HD: 18.6GB | 3.51GB Used | 15.1GB Free
RAM: 120MB
Display Adapters(From the Device Manager):
Trident Super VGA
VIA Tech VT8361/VT8601 Graphics Controller
The bottom Display Adapter is the one that i thought was the problem so i found a download on a site of it and added it, and the problem is still there.
Hope that helps to get this solved :)
Edited by TheBrotherhood313
  TheBrotherhood313 said:
OS: Windows 98
RAM: 120MB
Trident Super VGA
Such a rig should run fine under good ol' Win98.
You sure you've installed it's graphic driver correctly?
The graphic driver was default and it was messed up. I decided to look for a download on the web of that same driver and i found one. I downloaded and installed the new download of the driver and still the same problem.
I really have no idea whats going on or how to fix it.
Note: It used to work fine, something happend and now its not. The driver never was changed at all and it used to work. Not sure what happend, but now it just doesnt let me change from 16 colors :(
I think you just need to buy a new graphic card, sounds like the one you have only supports 16bit colors. They cheap now man, i bought me a ati radeon 7000 64mb pci card and it supports 32bit colors and works fine. You might wanna get a more updated one, maybe a cheap 9000 tho.
Have you checked device manager to ensure it is picking up your display adapter correctly and there are no red or yellow marks against the device?
Ensure the card is what it says by opening up the machine and checking inside.
You say there are two graphics cards? Maybe try the other one and see if that is working?
I've seen this a bunch of times where the Screen is set to a default monitor or something.. go to advanced in display properties, and change the monitor to Standard Monitor type SVGA 1024x768... then reboot and see if you can move the slider along :)
