Possible Fix for HL2 Sound Loop Crash
Recently Browsing 0 members
Posts
By Gerowen · Posted
They've been focusing on security and quality? Could have fooled me. Their own paying customers literally just got breached because they failed to push SharePoint updates downstream to on prem servers operating outside of their "365" ecosystem. -
By Gerowen · Posted
The animosity is unnecessary, when I opened the page I only saw one response which never mentioned your other steps, and when I hit reply it jumped straight to the bottom and again, I saw no other responses. I was simply agreeing with the first comment that said yes, you should be fine if you erase its current operating system. Using another PC, or the copy of Windows that comes on that PC (former option is more trustworthy), download and run the Windows Media Creation tool. It will walk you thru the process of downloading Windows and writing it to a USB stick. It will even ask you at one point whether you're reinstalling it to the current machine or installing it on another machine. Then just boot the PC in question from that USB stick. Usually spamming Esc, Del, F-8, F-9, F-10, F-11, F-12 or F-2 immediately after power on will bring up a boot menu, it varies by manufacturer. If Windows starts booting you either missed your window or hit the wrong key. Follow the on-screen instructions. When it gets to the disk formatting part I usually just delete all the partitions on the destination drive, then select the unpartitioned space as my destination. The Windows installer will then automatically partition the drive as needed. Be prepared to download drivers from the PC manufacturer's website, they may not come bundled with Windows and you may not be able to use things like WiFi or ethernet until you have them. They "might" work straight away, but they also might not. Better to be prepared with a spare PC and a USB stick to transfer them over. -
Wise Disk Cleaner 11.2.5 by Razvan Serea Wise Disk Cleaner is a free disk utility designed to help you keep your disk clean by deleting any unnecessary files. Usually, these unnecessary, or junk files appear as a result of program's incomplete uninstalls, or Temporary Internet Files. It is best if these files are wiped out from time to time, since they may, at some point, use a considerable amount of space on your drives. Wise Disk Cleaner, with its intuitive and easy to use interface, helps you quickly wipe out all the junk files. Using the program is indeed easy. It also works fast when both scanning for files and deleting files. The new Wise Disk Cleaner has more advantages: improved performance, better interface and scans/cleans more thoroughly. Wise Disk Cleaner Free provides lifetime free update service and Unlimited Free technical support. The first Slimming System software Wise Disk Cleaner is the first system slimming tool, which will help you to remove Windows useless files that you don't need, such as Korean IME, Windows Sample music, videos, pictures, Installers and Uninstallers of Updates Patches etc. Wise Disk Cleaner 11.2.5 Build 845 changelog: Added cleaning rules for Legacy Games Launcher, Letasoft Sound Booster, Macrium Reflect, MagicLine4NX, MAGIX Photostory, MakeHuman, Max Recorder, Maxprog iCash, Lexware, LG PC Suite, Lightworks, LINE, Listary, and LockHunter. Improved cleaning rules for Xunlei, PowerToys, Meitu, OneDrive, and Tencent Video. For security reasons, users can no longer delete the latest system restore point in the Restore Center. Enhanced System Slimming. Fixed minor bugs from the previous version. Download: Wise Disk Cleaner 11.2.5 | 6.9 MB (Freeware) Download: Portable Wise Disk Cleaner 11.2.5 | 7.3 MB View: Wise Disk Cleaner Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
By lsquare · Posted
I keep getting ignored when I ask what you guys mean by nuke it. I described the steps and I keep getting the same generic instructions. Can you look at what I have posted multiple times already and validate what I have described? You can't assume everyone has your level of expertise and can interpret your nuking advice. After this many posts in this thread, I don't think we need the same generic advice about just nuke it and reinstall. It's already been said. So can you please outline the specifics? Made in Ukraine? Are you sure? -
Recent Achievements
Itbob513626 earned a badge
EdwardFranciscoVilla went up a rank
MoJo624 earned a badge
aeganwn earned a badge
Collaborator
Popular Contributors
Tell a friend
