Command Prompt problems - help!
6 answers to this question
Sorry to say, but you are infected with a virus.
Cmd.com is a trojan, the command shell is started with cmd.exe.
Use a startup program like Startup Control Centre ( http://www.mlin.net/StartupCPL.shtml ) to remove unwanted .bat or .exe files and you'll have to remove suspect .com files that have been installed into your \windows directory as well.
Don't believe me? Click start/run and enter cmd.exe. Your command prompt will work.
Edited by ManMountain
586674863[/snapback]
Good eyes man! I didn't even see that myself.
Good catch, Didn't see that myself
