C web proxy not showing images
I programmed a web proxy in C and the pages seem to load fine. The only problem is images don't load up. I see all the requests for the images and see the data transmitted. When the messages are written to the browser, they don't show up. Anyone have an idea why this would be? What I'm confused on is do images have to be handled differently than the regular html text?
I'm reading everything from the web server(eg Google) into a char buffer of 2048 and write to the browser. This loops until there is nothing more to read. Like I said, the webproxy shows that there is information transferred, but I just get the red x.
https://www.neowin.net/forum/topic/397509-c-web-proxy-not-showing-images/
8 answers to this question
Is the proxy sending the HTTP headers correctly?
While browsers usually display HTML pages properly if the headers aren't there, they can't display images if the headers aren't there...
I learnt this while I was creating a small webserver. Browsers only started displaying images when I implented the "sendheaders" function. HTML on the other hand was always displayed properly, even without headers.
586806184[/snapback]
So I need to forward the entire request, including headers? I figured that just the GET request with the file and protocol was enough. I didn't think that I needed to include the entire header. Let me give this a try. Thanks for the explaination.
Still no luck getting the image to load. I just don't see how I can transfer the image data correctly with a character buffer. Does anyone have an idea how I can handle this data correctly? The information that is being passed to the browser is the same information when you open an image in notepad, garbled text and symbols. Any suggestions?
586809572[/snapback]
Be careful with your buffer, because it contains binary data if you use it for transferring images. Thus a string function like strlen() for example will likely not work --at least not all the time. You may want to consider an array of bytes instead.
The easy way to resolve your problem is to sniff on the network traffic with and without your proxy and then compare the results for the same requests, then you should be able to tell what is different when the proxy is enabled and it should be trivial to fix.
    • Display Driver Uninstaller (DDU) 18.1.2.3 by Razvan Serea Display Driver Uninstaller (DDU) is a utility for completely removing AMD/NVIDIA/INTEL graphics drivers and related packages from your system, attempting to eliminate all leftovers (including registry entries, folders and files, driver store). Though AMD/NVIDIA/INTEL drivers can usually be removed via the Windows Control Panel, this uninstaller tool was created for situations where standard uninstall fails, or when you need to fully remove NVIDIA or ATI graphics card drivers. After using this driver cleaner, your system will behave as though it’s the first time you’re installing a new driver—similar to a fresh Windows installation. As with all such tools, we recommend creating a restore point beforehand, allowing you to undo changes if issues arise. If you're having trouble installing an older or newer driver, try it—there are reports that it resolves such problems. Recommended usage: The tool can be used in Normal mode but for absolute stability when using DDU, Safemode is always the best. Make a backup or a system restore (but it should normally be pretty safe). It is best to exclude the DDU folder completely from any security software to avoid issues. You do NOT need to uninstall the driver prior using DDU. Requirements: .NET Framework 4.8 Compatible with Windows 7, 8, 8.1, 10, and 11 (32-bit or 64-bit) Note: Using on Insider Preview builds is at your own risk. Display Driver Uninstaller (DDU) 18.1.2.3 changelog: All GPUs: Fixed hardware rescan issue when cleaning all GPUs without restarting or shutting down UI: Added Guru3D mention in the About section. General: Various fixes and enhancements. Download: Display Driver Uninstaller (DDU) 18.1.2.3 | 1.7 MB (Freeware) Download: DDU Portable | 1.2 MB Links: Display Driver Uninstaller Home Page | Screenshot | Forum Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • That would be nice, if excel could refresh pivot tables without bugs. Frequently you refresh a pivot and all parameters get lost. Now this will happen automatically. Bravo MS!
    • If one could ever put all the crap of the world in one box, that would be Microsoft.
    • The most corrupt and vile CEO any company ever had ! The only company that makes an insane amount of money decade after decade but doesn't deliver on even barely passable quality to customers, screws over partners and treats employees like trash
      Homayoun Hotak earned a badge
      Profit earned a badge
      hhgygy earned a badge
      NIKI77 earned a badge
      167
      123
