Need Help Choosing a TFT monitor
Well... Gonna buy a TFT monitor for christmas and can't decide which one to get. It is betwen these:
Viewsonic 19'' TFT VX924 - (3ms)
Contrast Ratio 550:1
Brightness 270cd/m?
http://www.viewsonic.com/products/desktopd.../xseries/vx924/
Samsung 930BF 19" TFT Svart/Silver Analog&DVI 4ms>
Contrast Ratio 700:1
Brightness 270cd/m2
http://www.samsung.com/uk/products/monitor...19bidksvedc.asp
Samsung 940B 19" TFT Silver Analog&DVI 8ms>
Brightness 300cd/m2
http://www.samsung.com/uk/products/monitor...19habtsqedc.asp
Samsung 950B 19" TFT Silver Analog&DVI 8ms>
Brightness 300cd/m2
Samsung 960BF 19" TFT White Analog&DVI 4ms>
Brightness 300cd/m2
Hyundai L90D+ 19" TFT Silver Analog&DVI 8ms>
Brightness 300cd/m2
http://www.hyundaiq.com/pro_l90d+.asp
Acer AL1951Bs 19" TFT Silver Analog&DVI 6ms CrystalBrite>
Brightness 400cd/m2
Acer AL1951Bs
The monitor will be used for playing games like Battlefield2, Operation Flashpoint and others. And also will be used for school work, use Word, Photoshop, 3D Studio Max. The price difference is not much for any of them.
https://www.neowin.net/forum/topic/403009-need-help-choosing-a-tft-monitor/
Do not buy Samsung TFT's. Simple as that.
You'll be wanting a Dell 1905FP then, forget the supposedly low display timing issues others may whinge and woot about. This is simply the best 19" TFT money can buy, for gaming, watching movies or anything else you'd care to mention.
I've done my research, bought a few 19"ers and took them ALL back because they had all manner of problems, most notably, backlighting issues and viewing angle problems.
It's such a let-down when your new TFT lets you down badly, so please take my advice, for your own sake.
I have a Viewsonic VX910:
+ Awesome colours, brightness
- Awful viewing angle, even when looking head on at the monitor, the top and bottom of the screen appear darker.
3ms is a marketting point, as fun as it sounds. I use 12ms for competitive gaming and its 100% fine.
Check this out: Sony SDM-HS95P X-black 19" Example Link. Read many a great review about it. Tempted to buy one myself.
    • I commented on ONE thing, the rest is just an explanation for the unintroduced. The distinction between Skype and SfB was not cloud vs on-prem, period. That's all I refuted.
    • "that supports both AMD and Intel" Why even say such a thing? That's like saying an HDMI cable that supports both LG and Dell displays or something.
    • since when was a xx50 series GPU "good" this is another one of those "duh" what did you expect, kinda reviews.
    • Giga Computing launches liquid- and air‑cooled AI servers built on NVIDIA HGX B200 platform by Fiza Ali Giga Computing has today expanded its enterprise‑grade GPU server portfolio with four new systems built upon NVIDIA’s HGX B200 platform. These servers combine advanced cooling options with support for Intel’s latest AI‑optimised Xeon 6 processors. According to NVIDIA, HGX B200, powered by the company's Blackwell architecture, delivers up to 15 times faster real‑time inference, where the trained AI model makes predictions or decisions based on new data, on trillion‑parameter models compared to the previous generations. The 4U GIGABYTE G4L3 Series features separate CPU and GPU chambers and employs an advanced direct liquid‑cooling (DLC) system. According to the tech giant, this approach not only sustains peak performance during demanding AI training and inference tasks but it also drives down both power consumption and data‑centre cooling costs. The two variants which are currently available are the G4L3‑SD1‑LAX5, which supports the latest Intel Xeon processors, and the G4L3‑ZD1‑LAX5, which supports AMD EPYC CPUs. On the other hand, the GIGABYTE G894 Series uses optimised airflow and works with a variety of x86 platforms and baseboard GPU setups, including NVIDIA’s HGX B200. It comes in two models: the G894‑AD1‑AAX5, which supports Intel Xeon 6900‑Series processors such as the 6962P, and the G894‑SD1‑AAX5, which supports Intel Xeon 6700‑ and 6500‑Series processors, including the 6776P. GIGAPOD, Giga Computing’s AI supercomputing solution, has also been updated to include the new NVIDIA HGX B200 platforms. Built for the rigours of training large language models and generative AI, it promises improved throughput, higher energy efficiency, and a range of cooling options to accommodate advancing AI demands. With the addition of these HGX B200-powered systems to its lineup, Giga Computing is expanding its server offerings to better support demanding AI workloads. The focus on efficient cooling, compute density, and compatibility with the latest processors positions these new models as options for enterprises scaling up AI infrastructure.
    • OpenHashTab 3.1.1 by Razvan Serea OpenHashTab is a convenient shell extension that allows users to easily calculate and verify file hashes using file properties. It offers support for 28 different algorithms, ensuring compatibility with a wide range of hash types. With its high-performance hash calculation capabilities, OpenHashTab delivers efficient results. The extension seamlessly integrates with the Windows operating system, providing a native look and feel. It also offers support for high DPI screens and long paths. Additional features include multilingual support, the ability to check hashes against VirusTotal, hash checking against checksum files, hash export to file or clipboard, and optional context menu options for faster access. OpenHashTab supports file associations and can be used in standalone mode. OpenHashTab is compatible with Windows 7 or newer versions, supporting x86, x64, and ARM64 architectures. Usage Most of the actions should be obvious. Some not-so-obvious features are listed here: You can select multiple files or folders, all files will be hashed, directories traversed Double click hash to copy it Double click name or algorithm to copy the line in sumfile format Right click for popup menu: copy hash, copy filename, copy line, copy everything The counters next to the status text is in the format (match/mismatch/nothing to check against/error) Columns sort lexicographically, except the hash column which sorts by match type Selecting the tab on a sumfile will interpret it as such and hash the files listed in it. If a hashed file has a sumfile with same filename plus one of the recognized sumfile extensions and the option for it is enabled, the file hash is checked against it. Algorithms CRC32, CRC64 (xz) xxHash (XXH32, XXH64) xxHash3 (64 and 128 bit variants) MD4, MD5 RipeMD160 Blake2sp SHA-1 SHA-2 (SHA-224, SHA-256, SHA-384, SHA-512) SHA-3 (SHA3-224, SHA3-256, SHA3-384, SHA3-512) BLAKE3 (256 bit, 512 bit) KangarooTwelve (264 bit, 256 bit, 512 bit) ParallelHash128 (264 bit) and ParallelHash256 (528 bit) Streebog (GOST R 34.11-12) (256 bit, 512 bit) OpenHashTab 3.1.1 changelog: This release fixes a build problem with 3.1.0 causing StandaloneStub to be unable to start. Reduce the size of AlgorithmsDll Move installer to WiX, overall register components better Build x86 so that 32-bit explorer replacements can also have the extension Reintroduce x86 version since we're building it anyway Translation updates Download: OpenHashTab 64-bit | OpenHashTab 32-bit | ~8.0 MB (Open Source) Download: OpenHashTab ARM64 | 8.3 MB View: OpenHashTab Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      956400 earned a badge
      loose_observer earned a badge
      BeeJay_Balu earned a badge
      filminutz earned a badge
      SteveJaye earned a badge
      148
      Nick H.
      65
      +thexfile
      62
