Got problem with JAVA on XP plz help.
MS Virtual Machine -
http://ftp.anadolu.edu.tr/pub/Win9x/MS%20V...va/msjavx86.exe
This is the last one before they took it offline.
(UPDATE) - Direct from the MS Knowlege Base - MS Virtual Machine
http://support.microsoft.com/default.aspx?.../vm/dl_vm40.htm
Easier though is to get the plugin direct from SUN it runs smoother, and integrates with mozilla and other apps that need Java.
Sun XP Java Plugin -
http://dlres.java.sun.com/PluginBrowserChe...ava/others.html
Can these two ever decide to play nice.
the weird thing was is that i swear i had this installed, but when i was reinstalling openoffice today, it said no java found on the machine. so i just dl'ed the latest beta from java.sun.com and it fixed everythign up perfectly.
Originally posted by Tesseract
might need to make this a sticky so that people in the future that need ms java vm can d/l it from that link. man if sun and ms could just play fair. :D
True..
But, come on, think the super giant of M$ could let someone else run apps well without messing over it's own people also. Keeps you dependant on them.
If you really want M$ VM 3805 (java) - just grab the secuity update dated march 4th - some security fix for VM. It contains the full version of VM.
You have to grab it from the cat though - not just a scan on winupdate.
This update was still avail as of a few days ago - I would suggest you grab and put the msjavx86.exe somewhere safe - for later use :)
Originally posted by BroChaos
why don't you guys like the sun one?
It's slower ......
Most webpages are designed with I.E and Virtual Machine in mind and gives errors when used with SUN's Java only.
This isn't really SUN's fault but just the way things are.
Installed XP and now when the window pop ip in some web-site thet telling me thet i need to download JAVA then i geting this error
We're sorry. Automatic installation of Microsoft Virtual Machine is no longer provided for Microsoft Windows XP.
And i cont download and install JAVA
How can i sulv this ?
SUN Microsystems won a courtcase against Microsoft, so they cant give you Java anymore, if you need it , go to Sun's homepage
it does not even show up on windows update for me so my only solution is Sun
i assume sun's version is to the letter, and that is why it "sucks" where as ms's is crippled, and mildly propertiry.
i would also assume that if i was sun, and i won the case, then i would make DANG sure that new users would have a great exerience with java. know what i mean?
