Problem with errors in partition
I'm running winxp sp2 with 2 Seagare hard disks. EasyRecovery Pro and Seagte Tools reported that I have critical system structure in certain partitisions of my disks. So as advised by many websites, I did several checks with winxp's chkdsk which all reported no errors and fixed nothing. No bad clusters either.
This morning, I did another test with Vcom's Fixt-it and it reported that there's no error in my disks. Don't know what and who to believe and I dare not defragment just in case there's in fact something wrong. And BTW, I don't get cranky sounds from my PC and all the software that I've installed are running fast and efficiently.
Is there any other tools that I can use? I append below Seagate's report just in case it might explain my problem better.
Thank you.
File Structure Test Result:
Partition 1 (NTFS (8.1 GB) Reserve) Result: Passed
NOTE: Any report of possible errors in the file system tests are for
informational purposes only. We suggest you should consider testing with
the official file system diagnostic utilities for your operating system.
Seagate is not able to assist with troubleshooting or reviewing
file system test results.
Partition 2 (NTFS (1.7 GB) Misc) Result: Failed with critical Errors
The following errors were found while scanning the volume:
- One or more cross-links were found
- One or more errors were found in metadata file records
- Other errors were found
Partition 3 (NTFS (18.4 GB) Software) Result: Failed with critical Errors
- One or more errors were found in the index
Partition 4 (NTFS (11.7 GB) Standby) Result: Failed with critical Errors
Recommendation:
All selected physical diagnostics passed.
If you are not experiencing data loss and SeaTools reports File
System Structure errors, they may be caused by a lock-up or
failure to shutdown Windows correctly. Many times, these errors
may be repaired through normal system maintenance which
includes using the Windows provided "Defrag" and
"Scandisk / Chkdsk / Error Checking" utilities.
If you are experiencing a hardware error, you should isolate
the cause and replace the failing component. If you are unsure how
to proceed with repairs, contact a computer professional. After
completing any maintenance tasks, run SeaTools again to
verify that all errors have been repaired. If errors continue to
occur, the system may not be stable. Again, contact a computer
professional.
https://www.neowin.net/forum/topic/417647-problem-with-errors-in-partition/
