ATI Component out Virtual Desktop Problem
I have a Radeon 9800 PRO with a DVI to Component adapter which then hooks into my 76cm Widescreen TV
the TV can do 480i and 540i
I can do 480i - 720x480 just fine without virtual desktop, but when I do 480i 16:9 848x480, Virtual desktop turns on which I do NOT want to happen.
according to this link, it states that 848x480 is a supported mode and I should NOT get Virtual Desktop with 848x480
https://support.ati.com/ics/support/default...&task=knowledge
Why is virtual desktop turned on when I go to 848x480? is there a firmware update/fix
Thanks
for anyhelp
