Hi,
I have a problem with my network settings..
This is my network setup:
CLIENT -> (VPN) -> SERVER -> VMWARE IMAGE
When the vpn connection is made, the client can ping the server. Also the server can ping the image. BUT the client can not ping the image.
I'm not a network or vmware specialist. Do I need to activate a VMware network adaptor? or enable NAT translation on the server?
I found that more people have trouble with this, but couldn't find the right answer.
Here are my IP settings:
CLIENT
PPP-adapter idsserver:
Verbindingsspec. DNS-achtervoegsel:
Beschrijving . . . . . . . . . . .:
WAN (PPP/SLIP) Interface
Fysiek adres. . . . . . . . . . . : 00-53-45-00-00-00
DHCP ingeschakeld:. . . . . . . . : nee
IP-adres. . . . . . . . . . . . . : 192.168.168.200
Subnetmasker. . . . . . . . . . . : 255.255.255.255
Standaardgateway. . . . . . . . . :
DNS-servers . . . . . . . . . . . : 195.130.130.130
SERVER
Windows IP Configuration
Host Name . . . . . . . . . . . . : idsserver
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : Yes
PPP adapter RAS Server (Dial In) Interface:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.168.18
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . :
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Intel® PRO/1000 MT Network Connectio
Physical Address. . . . . . . . . : 00-14-22-0A-E9-BC
IP Address. . . . . . . . . . . . : 192.168.168.189
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.168.168
DNS Servers . . . . . . . . . . . : 195.130.131.2
195.130.130.130
VMWARE HOST
Host Name . . . . . . . . . . . . : ASDelt
WINS Proxy Enabled. . . . . . . . : No
Description . . . . . . . . . . . : AMD PCNET Family PC
Physical Address. . . . . . . . . : 00-0C-29-DC-F9-44
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.168.192
DNS Servers . . . . . . . . . . . : 195.130.130.130
https://www.neowin.net/forum/topic/440085-vpn-and-vmware-network-problem/
    • I would not mind paying 120 up to 150 dollars in this economy value of the dollar currency if their video game is quite breathtaking and excellent use of my hard earned work money. I think people need to appreciate all the effort workers and time that goes into excellent and worthy video games. Now if only the publishers and companies behind the video games would share the love with the developers those at the bottom of work making such games happen as in increase their money accounts and give them a more richer life that I wish would have happened . But how companies have bad reputation of being $$$ profit greedy I feel sad if there are any developers that feel unappreciated as in no real compensation for all the hours of work they put into a blockbuster hit . Have a great day everyone . Thank you developers engineers and programmers that make superb video games happen . You have my thanksgiving and I hope you really really appreciate my words . With you all about this
    • I guess they use the free version, which doesn't send money to any Russians.
    • True, you can pin it to the Start Menu, but my preference is to pin it to the Taskbar since I am using W11 on a desktop with a large display and a lot of space on the Taskbar.
    • 200 mph. Try going 200 mph with a vehicle on a street in any city in America. Good luck. Yes its speculation but so is the idea that it has been 100% approved by the government. When a new drug is under development it goes through a number of test phases, each of increasing efficacy and safety. I would imagine it is the same in this case. You can similuate real conditions on test roads with other cars and if successful on test roads you move it to the next test phase of testing it on real streets with human assistance if needed. Testing conditions on test roads can never account for all real life situations on real roads. This is what I imagine is happening now. The final test phase.
      Hartej earned a badge
      TsunadeMama earned a badge
      shaheen earned a badge
      Cole Multipass earned a badge
      Alexander 001 earned a badge
      183
      Skyfrog
      112
      Som
      106
