KVM Switch Problem
Hey guys, this is also my first post on here so Hi lol.
Anyway, I have a 2-Port Belkin KVM switch with USB. Now, whenever I flick the switch over to the 360 so it works on the monitor, within a few seconds it takes me back to the PC, without notice. I can't stop this, and its really annoying, does anyone have any suggestions please! Oh and when I click switch by using the software, my scroll lock flashes on my keyboard??
Any help is appreciated, thanks.
Edited by deadwar
https://www.neowin.net/forum/topic/442552-kvm-switch-problem/
What is happening is that it is going back to your computer cause you aren't telling it stay on the XBOX what you need to do is when using the software and the scroll lock flashes just push ESC on the keyboard. that will lock it to the xbox and it won't swtich back over. There should also be some short cut keys your can press on the keyboard that will change it over as well. Just always make sure you push the escape key after switching over, so that it locks it.
Hope this helps
Hope this helps
Thanks man, this really helps! I've disconnected everything so I have to do it tomorrow now, so I'll tell you how I get on.
Sorry for a triple post, but this needs bumping instead of editing - today I do exactly what i did yesterday to get the switch working, when I click switch scroll lock flashes, I click ESC but now nothing happens.
EDIT - Ok now when I click ESC it does take me to the 360, but doesn't stick.
Edited by deadwar
    • There won't be any major changes from beta to release.
    • Having been using Windows for 30 years and 3 Surface Pros in the meantime (4,6,9) and recently bought a 15" macbook air m4. The OS is indeed a big deal. Hardware wise the surface pro feels as nice as macbook air, but Windows...man it's it's own enemy now
    • 2013 to 2017...wtf, is Steve on the wacky tabacky? Never heard of this or this Nathan guy in Australia.
    • Dell says it can't be blamed for Windows Night Light breaking on its Arm PCs by Usama Jawad Night Light is a very handy feature that is available by default in Windows 10 and Windows 11. Essentially, when you toggle it on, Windows reduces the emission of blue light from the display which in turn decreases the stress on eyes and can potentially aid in better sleep too. While this feature generally works quite well, this hasn't been the case so far on some Dell PCs. Now, Dell has acknowledged the issue in a recently published support document. As the situation currently stands, Night Light does not work on the secondary display on certain Windows Arm PCs when an external monitor is connected to them. This happens on the following PC models: Inspiron 14 5441 Inspiron 14 Plus 7441 Latitude 5455 Latitude 7455 XPS 13 9345 Now, Dell has confirmed that this is not due to any hardware or software issue on its side, it's just a limitation of the Qualcomm Oryon chipset. In essence, this is a problem that is outside the control of Dell. What this means is that while customers can utilize built-in and third-party tools to adjust the color profiles of their displays, Dell can't really get Windows Night Light to work as-is on external displays connected to any of the Arm PCs listed above. The company has emphasized that there are no plans to support Windows Night Light on its existing Arm PCs, and that customers will just have to make do with what they have. However, this feature will likely work as designed with the "next generation" of Arm computers, which will presumably leverage a chipset that is not held back by this limitation. Windows on Arm has enjoyed decent support from software developers in recent times; Microsoft will be hoping that it can keep the momentum going with its next Snapdragon PCs.
    • that car they are showing run on very small areas and in controlled environments like no difficult intersection or construction areas while also having drivers in the car, while waymo has proven track record, one is working product which you can take today, the other is future promise with less service and more caveats (which has been delayed over a decade).
      moojay67 earned a badge
      lethalman earned a badge
      B4dM1k3 earned a badge
      adnan.hebibovic earned a badge
      144
      135
