- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
_R2D2
I installed netlimiter an hour ago. When I rebooted, it was terribly slow, so I removed the folder in program files (don't ask me why). Now when I rebooted again, netlimiter is gone. But now my internet doesn't work. Windows says "limited or no connectivity". I've tried removing all netlimiter info in the registry and uninstalling my network card, but without results.
What should I do?
My xp cd is non-sp, but I'm running sp2, so I can't do a repair install.
https://www.neowin.net/forum/topic/444478-netlimiter-problems/Share on other sites
11 answers to this question
