Help on an SQL Query
Say I have 2 tables:
Table Employee
| id | firstname | surname |
| 1 | John | Smith |
Table Allowances
| employeeid | type | amount
| 1 | communication | 100
| 1 | car | 1500
My current SQL is
SELECT e.id, e.firstname, a.employeeid, a.type, a.amount
FROM employee e, allowances a
WHERE e.id = a.employeeid
This will gives me some rows of "semi-duplicates" like:
Row 1: 1, John, Smith, communication, 100
Row 2: 1, John, Smith, car, 1500
Would it be possible to have an SQL query where the result is like:
|id|firstname|surname|communication_allowance|car_allowance|
1, John, Smith, 100, 1500
https://www.neowin.net/forum/topic/449949-help-on-an-sql-query/
4 answers to this question
you need to use a subquery.
Something like:
Select id, firstname, lastname, (select amount from Allowances where
employeeid =id and type='communication') as communication_allowance,
employeeid =id and type='car') as car_allowance
FROM employee
Just realized yours was a MySQL question.
I don't know MySQL -- only MS SQL Server.
So this might not work.
Table Employee
| 1 | John | Smith |
Table Allowances
| 1 | car | 1500
My current SQL is
I not sure whether this works, I'm trained on Oracle SQL though I used mySQL a number of times.
e.surname,
(select a.amount from allowances a where a.employeeid = e.id and a.type = 'communication' and rownum = 1) "communication_allowance",
(select a.amount from allowances a where a.employeeid = e.id and a.type = 'car' and rownum = 1) "car_allowance"
from employee e
Note that this works only when there is only 1 row per allowance type, per employee id in allowances. (Hence the rownum = 1).
It depends. If you already know the employee types are constant then it's pretty easy with the subquery methods mentioned before, but it also means that your data model is flawed... But if the employee types are not constant, then the subquery method won't work since it only looks for "car" and "communication". Any other types wouldn't show up. It's still possible, but I only know of a way to do it in MS SQL 2005 with the PIVOT option. I don't know if Oracle or MySQL have a similar feature. Basically it just makes the rows the columns and the columns the rows.
    • This 2TB NVMe Gen4 SSD is priced just $94 and you also get a free 64GB UHS-I memory card by Sayan Sen A few days ago, we reported on Team Group's T-FORCE G50 4TB NVMe SSD that was up for grabs at just $200 thanks to a promo coupon. Sadly, that deal has expired although you can still WD's SN8100 (Gen5) and SN7100 (Gen4) offerings as they are still running the discount. If you don't have the budget for those or are shopping for lower capacity drives then Crucial's T500 Gen4 drive discount is still live, and you can get them for just $125. And while the G50 4TB deal has expired, Team Group is now offering its 2TB model at its lowest ever price and you also get a free Micro SD card with it. The Team Group G50 is also a TLC (triple level cell) NAND flash SSD, and thus the endurance on the T-FORCE SSD is quite good, as it is rated for 1300 TBW (terabytes written) for the 2TB variant. Its MTBF, or Mean Time Between Failure, is claimed at 3,000,000 hours. The operating temperature is 0~70 C. The G50 does not have a dedicated DRAM cache (only the G50 Pro SKUs have it), but since it is based on NVMe version 1.4 which supports HMB (host memory buffer) technology; thus, the drive can use system memory for caching. In terms of performance, Team Group promises sequential read and write speeds of up to 5000 MB/s and 4500 MB/s, respectively. However, the firm does not disclose random throughput metrics. Get the Team Group G50 at the link below (deal is said to be ending in less than 10 hours): Team Group T-FORCE G50 SSD (TM8FFE002T0C129) + Team Group 64GB Elite microSDXC UHS-I U3, V30, A1, Micro SD with SD Adapter, to 100MB/s (TEAUSDX64GIV30A103): $105.99 + $12 off with promo code SSETA665 (Shipped and Sold by Newegg US) This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
    • I know what you're getting at, but Microsoft themselves have said that the Xbox Ally specifically disables a bunch of stuff from Windows to improve performance and save 2GB of memory. And that special game mode is coming to Windows 11 next year.
    • It could be good old fashion neglect, lower priority focus, less resources then it use to vs active sabotage.
      Ian_ earned a badge
    • Explorer
      JaviAl went up a rank
      Explorer
      Cole Multipass earned a badge
      JLP earned a badge
      Rhydderch earned a badge
      184
