- 0
[C++] Telnet Authenticate Password problem.
Recently Browsing 0 members
Posts
QOwnNotes 25.8.0 by Razvan Serea QOwnNotes is a open source (GPL) plain-text file notepad with markdown support and todo list manager for GNU/Linux, Mac OS X and Windows, that (optionally) works together with the notes application of ownCloud (or Nextcloud). So you are able to write down your thoughts with QOwnNotes and edit or search for them later from your mobile device (like with CloudNotes) or the ownCloud web-service. The notes are stored as plain text files and you can sync them with your ownCloud sync client. Of course other software, like Dropbox, Syncthing, Seafile or BitTorrent Sync can be used too. Features: the notes folder can be freely chosen (multiple note folders can be used) sub-string searching of notes is possible and search results are highlighted in the notes application can be operated with customizable keyboard shortcuts external changes of note files are watched (notes or note list are reloaded) older versions of your notes can be restored from your ownCloud server trashed notes can be restored from your ownCloud server differences between current note and externally changed note are showed in a dialog markdown highlighting of notes and a markdown preview mode notes are getting their name from the first line of the note text (just like in the ownCloud notes web-application) and the note text files are automatically renamed, if the the first line changes compatible with the notes web-application of ownCloud and mobile ownCloud notes applications compatible with ownCloud's selective sync feature by supporting an unlimited amount of note folders with the ability to choose the respective folder on your server manage your ownCloud todo lists (ownCloud tasks or Tasks Plus / Calendar Plus) or use an other CalDAV server to sync your tasks to encryption of notes (AES-256 is built in or you can use custom encryption methods like Keybase.io (encryption-keybase.qml) or PGP (encryption-pgp.qml)) dark mode theme support theming support for the markdown syntax highlighting all panels can be placed wherever you want, they can even float or stack (fully dockable) support for freedesktop theme icons, you can use QOwnNotes with your native desktop icons and with your favorite dark desktop theme support for hierarchical note tagging and note subfolders support for sharing notes on your ownCloud server portable mode for carrying QOwnNotes around on USB sticks Evernote import QOwnNotes is available in many different languages like English, German, French, Polish, Chinese, Japanese, Russian, Portuguese, Hungarian, Dutch and Spanish QOwnNotes 25.8.0 changelog: More warning log messages were ignored for Qt 6.9.1 Download: QOwnNotes 25.8.0 | 71.4 MB (Open Source) Download: QOwnNotes for Other Operating Systems View: QOwnNotes Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
Patch My PC - Home Updater 5.3 Final is out.
By d5aqoëp · Posted
7-Zip developer is quite stubborn as he refuses to support Windows 11 right click context menu. -
By zikalify · Posted
Duolingo's AI content push backfires; an entire course loses key words by Paul Hill Duolingo has taken to its blog to outline how it’s using artificial intelligence to speed up course creation. The language learning platform now says it’s using an automated AI system for the creation of new sentences in courses that previously took hundreds of hours to do manually. The new system aims to reduce manual editing, help to automate the process with AI, and create a modular system. It consists of three main parts: Generation (creates sentence candidates from pedagogical plans), Evaluation (tags sentences with assessments like "logically coherent" or "grammatically correct"), and Selection (chooses the best sentences that meet specific criteria). So far, the new system has been used to generate and launch content for many of its Spanish courses, but it will soon expand this. This comes after CEO Luis von Ahn caused a stir by claiming Duolingo would stop using contractors to do work AI can handle. This caused a backlash which made the company confirm it’s still dependent on its employees and AI won’t replace what they do. One of the most critical parts of the system is the evaluators which ensure high-quality content. The evaluators are mostly AI prompts that perform objective and subjective assessments of the generated content. Engineers at Duolingo came to realize that AI is better at checking its own output than generating it which is why evaluators are important. Duolingo isn’t totally excluding humans from this process, the company learned that human-curated data is essential to steer LLM’s correctly. While it’s quite an impressive step, it’s not without issues. Observability was found to be crucial as the automated system’s behavior was tricky to manage and understand. One example of failure was when the system created an entire French course without using the French words for “and” or “or” - essentially making the material useless as these are very common terms. The company said this was a surprise but has since been addressed. Now that the system is mostly working, the company is expanding it to other languages like Italian and Chinese. It’ll be interesting to see whether it helps the company make new language courses quicker as there has been a noticeable lack of new languages added for English speakers in recent years. -
By adrynalyne · Posted
I guess they took a page from Valorant devs. It also requires TPM 2.x.
Recent Achievements
bullgod69 earned a badge
Collaborator
Ed B went up a rank
Enthusiast
Xinotema earned a badge
Edward266 earned a badge
Markvens earned a badge
Popular Contributors
Tell a friend
Bi0haZarD
*EDIT* Solved...
Ok, i'm pretty new to C++, but i've written a telnet server that requires authentication of a password when the person connects. in Windows Telnet (telnet.exe) it works fine. yet if i use PuTTY telnet it fails authentication..
I used fstream to write the password to a text file and the result of the password sent(to make sure the pass was the same)
In Windows Telnet i got this response.
741258 (which is the password so it works)
yet in PuTTY Telnet i get this response.
???? ????'??????741258 (obviously it fails, but thats whats being sent to the server)
any idea of why this is occuring? and any way of fixing it?
*edit*
hmm... just tried with another client to check if it was a setting from Putty causing this.. and it worked with that client. so it seems its just a setting problem in PuTTy.
*edit2*
hmm.. changed the setting in putty from "telnet" to "raw" and it works.. it works so i'm not complaining lol.
Edited by Bi0haZarDLink to comment
https://www.neowin.net/forum/topic/462549-c-telnet-authenticate-password-problem/Share on other sites
0 answers to this question
