Wireless Networking...
Question:
If you have a PCMCIA Wireless Network Card in a Laptop, can you just buy a USB Wireless Network Adapter and do peer-to-peer for 2 computers that way or do you have to buy a Wireless Access Point router?
I'm looking at getting a Linksys PCMCIA and a USB Wireless Network adapter without a hub and hoping they can talk to each other on their own...
https://www.neowin.net/forum/topic/46763-wireless-networking/
Unlike wired networks, wireless networks have two different modes in which they may be set up: Infrastructure and Ad-Hoc. Choosing between these two modes depends on whether or not the wireless network needs to share data or
peripherals with a wired network or not.
If the wireless network is relatively small and needs to share resources only with the other computers on the wireless network, then the Ad-Hoc mode can be used. Ad-Hoc mode allows computers equipped with wireless transmitters and receivers to communicate directly with each other, eliminating the need for an access point. The drawback of this mode is in the fact that, in Ad-Hoc mode, wireless-equipped computers are not able to communicate with computers on a wired network. And, of course, communication between the wireless-equipped computers
is limited by the distance and interference
directly between them.
thanks guys.
I bought the Linksys PCMCIA and the USB Adapter and they wouldn't work. DO NOT buy these if you are using XP. Tech Support admitted to me that they dont work with each other. Wheee. I found that out after 10 hours of trying to get them to work.
I bought a D-Link DI-614+ AirPlus Router & Access Point and an AirPlus PCMCIA 650+ and my sweet lord, it was a breeze. Plugged the stuff in and what it showed on the screenshots in the intallation walkthrough mapped the process perfectly! Flawless.
D-Link wins in my books.
Originally posted by grafXguru
thanks guys.
Yeah, people told me linksys was better, but I got a D-Link pccard and access point, for almost half the price, and it works great :)
Actually the Linksys has worked great for me but I haven't tried their USB ... I have a D-link wireless PCI card and it works with my Linksys Wireless Router ...
I have the following:
Linksys BEFW11S4 EtherFast? Wireless AP + Cable/DSL Router w/4-Port Switch
http://www.linksys.com/Products/product.as...rid=23&prid=173
Linksys WMP11 Instant Wireless PCI Card
http://www.linksys.com/products/product.as...rid=22&prid=196
DLink AirPlus DWL-520+ PCI Card
http://www.dlink.com/products/digitalHome/...s/11b+/dwl520+/
I believe my brother has a DLink Wireless Router and a Linksys wireless PCI card and a Linksys PCMCIA card that all plays together ... Both of us have WinXP on all our computers ...
