Building a catapult for physics class.
I'm an engineering student so i could probably give you pointers.
-what level of physics are you at?
I would really recommend doing some simple newtonian calculations like trajectories, force, acceleration, velocity, mass, energy, or whatever you need to get the object flying.
If you don't know how to calculate any of those then taking a ruler and flinging an eraser is probalby good enough :p (seriously, something simple like that may work) like take a large piece of bendable plastic and stick it to something.
umm, i'm taking physics H. the one offered in high school. And i would do sumthing simple, but it has to launch a golf ball, and i sort of want to win the "farthest golfball launched" position.:ninja:
disclaimer: i'm in engineering but "modern", basically anything high-tech, engineering and only 1st year.
A nice long piece of stiff but bendable platic shoud do the trick. the launcher is up to you. perhaps a cup or something.
with grade 10 math and grade 11 physics knowledge you should be able to do some math to figure out the optimal angle.
