Logitech Setpoint not saving settings
Hey,
I'm using setpoint for my mx3100 keb/mouse combo and I have uberoptions installed. But my setpoint settings aren't saved. Whenever I reboot my mousespeed setting are reset as are the settings for the function keys on my keyboard. This is really starting to get annoying.
Any help?
thanks
hmmm, can't think why that would be a problem but since I don't have a solution yet, I might as well try it. I've changed the setting and I will reboot when I can. Right now the pc is in the middle of encoding some recordings.
I do remember that the settings of which system tray icons should be hidden and which should not, would get deleted sometimes. Maybe that's a connection with the problem...
Found the problem. I remembered I used a tweak a pretty long time ago to let windows xp shutdown faster and it seems that setpoint isn't closed correctly then. The tweak I'm referring to: http://tweakxp.com/article37045.aspx I just restored the default settings and now setpoint remembers my settings.
