[help] display properties won't open
yes that is right... when i right click and selected properties on desktop it does nothing same thing when i try to do it through control panel... im thinking i'll have to take the files that its for from my xp cd but, i don't know what files controls the display properties.
https://www.neowin.net/forum/topic/490469-help-display-properties-wont-open/
I've got that problem a few times before, try shutting off the system and then trying it again, if that doesn't work then you may have to look at doing a restore, or a reinstall. Normally when you reboot it fixes the problem.
