Ubuntu 6.0.6, wireless networking help
Ok so i've just switched from XP to ubuntu it is now my os on my pc must say im liking it so far, I need help with setting up a wireless network connection to my router the card i am using is a Belkin F5D7000UK i believe or it could be the F5D70001UK pretty sure it's the second one it's detecting the card and and in the ubuntu wiki it does say it is supported but yeah i am a n00b so i need a shove in the right direction.
Here are the details from the Device Manager:
"Device Tab"
Vendor: Broadcom Corporation
Device: BCM4306 802.11b/g Wireless LAN
Status: Status
Bus Type: PCI
Device Type: Unknown
Capabilities: Unknown
"PCI Tab"
Product: BCM4306 802.11b/g Wireless LAN
OEM Vendor: Belkin
OEM Product: Belkin F5D7001 High-Speed Mode
"Advanced Tab"
Key - Type - Value
info.bus strlist pci
info.linux.driver strlist bcm43xx
info.parent strlist /org/freedesktop/Hal/devices/computer
info.product strlist BCM4306 802.11b/g Wireless LAN Controller
info.udi strlist /org/freedesktop/Hal/devices/pci_14e4_4320
info.vendor strlist Broadcom Corporation
linux.hotplug_type int 1 (0x1)
linux.subsystem strlist pci
linux.sysfs.path strlist /sys/devices/pci0000:00/0000:00:0b.0
linux.sysfs_path_device strlist /sys/devices/pci0000:00/0000:00:0b.0
pci.device_class int 2 (ox2)
pci.device_protocol int 0 (0x0)
pci.device_subclass int 128 (0x80)
pci.linux.sysfs_path strlist /sys/devices/pci0000:00/0000:00:0b.0
pci.product strlist BCM4306 802.11b/g Wireless LAN Controller
pci.product_id int 17184 (0x4320)
pci.subsys_product strlist Belkin F5D7001 High-Speed Mode Wireless G..
pci.subsys_product_id int 28673 (0x7001)
pci.subsys_vendor strlist Belkin
pci.subsys_vendor_id int 6041 (0x1799)
pci.vendor strlist Broadcom Corporation
pci.vendor_id int 5348 (0x14e4)
when i run iwconfig in the terminal i get:
lo no wireless extensions
etho0 IEEE 802.11b/g ESSID: "belkin54g" Nickname: "Broadcom 4306"
Mode:Managed Access Point: Invalid Bit Rate=1 Mb/s
RTS thr:off Fragment thr:off
Link Quality:0 Signal level:0 Noise level:0
RX Invalid nwid:0 Rx invalid crypt:0 Missed beacon:0
sit0 no wireless extensions
Edited by a-d-i-d-a-S
https://www.neowin.net/forum/topic/503399-ubuntu-606-wireless-networking-help/
thanks for the links kreuger but i have'nt been able to get anywhere with them, should i just go for the "ndiswrapper" way of getting it to work or by tring to get the driver for the card from a windows cd or from the disc that i got with the card?
now im having trouble getting ndiswrapper to install i dont have a clue what to do, i think that to install it you have to do it via commands in the terminal but im not getting no where,
i've read all over the web about how to get ndiswrapper working but all the guide's are just not very well written if someone could show me how to do it i would appreciate it, i've been at this all day
i have the .sys and .inf file's that i need
