Ut2003 Problems
Well, I bought a new graphics card. It's a Radeon 9000 Pro 128MB
only problem is I can't run UT2K3. If I try running the regular exe, it spins the cd drive, the hard drive light flashes, this happens for about 2 min, and then it quits. I try running the Udebugger (which is how I ran it before, don't ask me...), I get this:
<?int?Udebugger.General.Abbreviation?> Build UT2003_Build_[2002-10-28_01.28]
OS: Windows XP 5.1 (Build: 2600)
CPU: AuthenticAMD PentiumPro-class processor @ 904 MHz with 319MB RAM
Video: No Video
General protection fault!
History: MainLoop
Here's the TS I've gone through so far.
reinstalled UT2K3, updated UT2K3 to 2163, updated to Catalyst 2.4 drivers, updated via 4in1 drivers, reinstalled dx8.1b, installed "special" driver from viaarena, installed ati brownout d3d driver, tryed running in openGL, tried CD in two different CD drives
system specs:
Athlon Thunderbird 900
FIC AZ11 KT133 mobo
ATI Radeon 9000 Pro 128MB
SoundBlaster Live! Value
320MB PC133 DRAM
I was running a GeForce2 GTS 32MB before I installed the graphics card and it worked fine (little slow of course, but it ran!)
HELP!
Edited by JaredVolkl
https://www.neowin.net/forum/topic/51072-ut2003-problems/
Ahhhhhhhh! I got that error too when I played the demo and I think also with the final build. Eventually it never came up again. I have a Radeon 8500LE 128MB DDR.
The best thing I can tell you to do is to get any patches for UT2K3. Other than that, maybe you could put up with it for a while and see if it somehow works itself out sort of like mine.
https://www.neowin.net/forum/topic/51072-ut2003-problems/#findComment-511890
that normal ati drivers always screw stuff up
try the newest patches
also try running the game in opengl and in directx
open ut2003.inf in (unreal tournament 2003 folder)\system
and go down to
[Engine.Engine]
RenderDevice=D3DDrv.D3DRenderDevice
;RenderDevice=Engine.NullRenderDevice
;RenderDevice=OpenGLDrv.OpenGLRenderDevice
AudioDevice=ALAudio.ALAudioSubsystem
NetworkDevice=IpDrv.TcpNetDriver
DemoRecordingDevice=Engine.DemoRecDriver
Console=XInterface.extendedconsole
GUIController=XInterface.GUIController
right now is set to directx
so switch to opengl
put ; in front of RenderDevice=D3DDrv.D3DRenderDevice
and erase ; from ;RenderDevice=OpenGLDrv.OpenGLRenderDevice
and save the file
now the game will run in opengl
https://www.neowin.net/forum/topic/51072-ut2003-problems/#findComment-512363
    • Guess I'll be saving the APK for future use, screw that data-harvesting copilot crap...
    • Looks like it, I have them working after the update.
    • MEmu Android Emulator 9.2.6 (offline installer) by Razvan Serea MEmu is a FREE Android emulator that brings fun of the Android experience to Microsoft Windows devices. It runs on nearly all Windows devices (PC, notebook, 2-in-1 devices, tablets). Comparing to other Android emulators, MEmu provides the highest performance and greatest compatibility. The richest features: Full Android experience with an elegant desktop Flexible customization (CPU#, memory size, resolution, device model, nav bar location, root mode, etc.) Mapping the keyboard / joystick to screen touch for much better game experience Passing through sensor data (e.g. accelerometer) to Android, so you can play car-racing like games intuitively GPS location simulation File sharing between Windows and Android Fast APK installation by drag and drop One-click Android system creation / clone / deleting, and you can run multiple Android instances simultaneously Using MEmu, you can: Have fun playing Android games on PC Chat more conveniently by using keyboard in Whatsapp, Wechat, etc. Watch live show and TV channels Ten seconds to start Directly open several Android Emulator windows MEmu Android Emulator 9.2.6 changelog: Optimized the emulator GUI to support native Windows 11 style. Optimized APK export speed, automatically export to shared directory, and display export progress. Fixed an issue where APK export could occasionally result in incomplete files on Android 12 instance. Fixed graphical corruption issues in Project Net game. Download: MEmu 9.2.6 Offline Installer | 639.0 MB (Freeware) View: MEmu Home Page | MEmu Support Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • You already have local admin rights. It is not really as bad as they say.
      Yawdee earned a badge
      eugwalker earned a badge
      Ben Gross earned a badge
      chiptuning earned a badge
      harveycoleman123 earned a badge
      189
      133
      wakjak
      107
