[VB .NET]Finding Min and Max
5 answers to this question
  weenur said:
ArrayList.Sort()
dim min as Integer = ArrayList[0]
dim max as Integer = ArrayList[ArrayList.Count - 1]
That's like an O(nlgn) operation. Not very efficient. The most efficient really is just looping through the array once. I'm that very well versed with vb.net so I can't just type the code here, but basically:
1. Set the variables min and max as integers to the first value of the array (position 0).
2. loop through the array. for each element, if it is larger than max, set max = that value. if it is smaller than min, set min = that value
3. when the loop ends, max and min will be the values you are looking for.
Mistook 'efficient' for simple.
Here is how i would do it with looping....
Hope this helps...
Module Module1
	Sub Main()
		Dim numList As New ArrayList
		numList.Add(1)
		numList.Add(5)
		numList.Add(3)
		numList.Add(15)
		numList.Add(25)
		numList.Add(5)
		Console.WriteLine("Maximum: " + DetermineMax(numList).ToString())
		Console.WriteLine("Mininum: " + DetermineMin(numList).ToString())
		Console.ReadKey()
	End Sub
	Public Function DetermineMax(ByVal itemList As ArrayList)
		Dim max As Integer = Nothing
		For i As Integer = 0 To (itemList.Count - 1)
			If i = 0 Then
				max = itemList(i)
			Else
				If itemList(i) > max Then max = itemList(i)
			End If
		Next
		DetermineMax = max
	End Function
	Public Function DetermineMin(ByVal itemList As ArrayList)
		Dim min As Integer = Nothing
			If i = 0 Then
				min = itemList(i)
			Else
				If itemList(i) < min Then min = itemList(i)
			End If
		Next
		DetermineMin = min
	End Function
End Module
    • Gemini CLI brings AI smarts to your Firebase terminal experience by Paul Hill Google has added its Gemini AI model directly into the command-line interface of Firebase Studio, its cloud-based IDE that uses AI to help with projects. The Gemini Command Line Interface (CLI) means that developers can expand past using AI for code, they can now also use AI for content generation and research without leaving the IDE. Gemini CLI comes with free usage tiers (60 model requests per minute, 1,000 requests per day with a Google login), it offers advanced AI features, and includes integrated Google Search for real-time content. Gemini CLI is also open source so it can be customized and accepts contributions. Accessing the Gemini CLI within Firebase Studio is straightforward, just press “Code view” in the top-right. From there, open up the terminal from the burger menu then select Terminal and New Terminal. Then in the terminal, type gemini and go through the setup, you can just press enter twice to get started. Out of the box, you’ll be able to get started with Gemini 2.5 Pro by just typing a query and pressing enter. There is also a non-interactive mode that’s useful for scripting and automation. To use it you use the –prompt or -p flags followed by your query wrapped in quotes, for example: gemini -p “What is the capital of France?” In this mode, Gemini CLI automatically closes after completing the request. During setup, there was the option to choose a theme. If you ever want to change it or look at other settings such as usage states, tool access, or checkpointing, you can edit them via .gemini/settings.json. You can also add API keys or choose different models in .env and you can using GEMINI.md to provide project-specific context, instructions, and coding styles in Gemini for a more tailored response. With Gemini CLI, you can have it explain code, refactor code, debug errors, and summarize information. It’s as simple as typing explain [file], refactor , debug “Error message”, or summarize “topic”. There are also built-in commands for managing the session such as /help for a command list, /chat to save and resume conversations, /tools to see available tools, and /restore to undo tool-made file edits. Firebase Studio, in true Google fashion, is a cloud-based IDE used in your web browser, making it excellent for weaker computers. To get started, you can head to the Firebase website. From there, tap Studio in the top-right.
    • I would prefer local ai over online ai on some tasks . They are good enough for tasks like artificial voice , image editing , text corrections , tagging etc . Local AI on Windows Photo editor is impressive for example . There are probably many other Ai that we could run on simple pc with GPUs .
    • oh look, we are under the control of the U.S again, is it not about time we as a country did this ourselves if they want it, not rely on greedy U.S. tech companies? We are capable of doing so as a country. I hate how the U.K have gone with no industry like we used to have and relying on other countries. Maybe we should follow Trump words, and make Britain great again and stop bending over to please Trump and other countries. Our government is Trumps puppet. I know we need to co-operate on some things, but come on.
    • Actually I see no problem is notifying readers in advance. The post author mentioned that it'll be available on July 22.
    • We can actually disable this new AI powered tab groups suggestion feature. https://www.askvg.com/enable-o...mart-tab-groups-in-firefox/
      MIghty Haul earned a badge
    • Collaborator
      KD2004 earned a badge
      Collaborator
      ataho31016 earned a badge
      Delahenty Machinery earned a badge
      140
      127
