- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
TanuKi Beard
Guys, I've been installing some linux distros, testing them out. An now I'd like to get back to windows, using the whole hard drive, so I'm planning on merging partitions with Partition Magic, I've heard of dirty issues regarding Partition Magic. I mean, is it true once I uninstall it after the merging procedure, my hard drive will encounter problem, or let's say there is a fuse in the house and the power goes off, and the PC shuts down, wouldn't that screw the hard drive. Anyways, those are simple rumors, but I'd like to have the true facts from you PC, Techie, pro geeks ;)
https://www.neowin.net/forum/topic/519934-risks-in-using-partition-magic-8/Share on other sites
18 answers to this question
