Questions on overclocking my CPU and Vid
Ive heard my mobo/cpu and vid card are very over clockable? Im technically solid but never overclocked before, and cant afford to blow a PC. Looking for advice, lots of info and questions to follow.
Basically I need to increase performance at the absolute lowest cost. I really only have about 150$ to play with.
My ps is only 300 watts. So I would probably have to replace it if over clocking will draw more (and from what ive read it will?).
So I was thinking either a new case with PS and fans. Then overclocking CPU and potentially the Vid card.
Other options include a dedicated sound card, or a new HD and running RAID (0 is supposedly faster... Would that be of benefit?).
Couple last questions if I understand correctly I can DL
"Clockgen: A real time adjuster of HTT, resulting in a new CPU speed, HTT and memory speed, but sadly, if you don't have a PCI/AGP lock, this program wont help you further." http://wiki.extremeoverclocking.com/wiki/A64_Guide
And as long as the changes I make are stable, then it will handle overclocking for me? And if I have this PCI lock, then I can do the vid card? Can I overclock the CPU and leave the RAM and Vid card alone?
Some of my systems Specs (ask if you need something else):
Field Value
Computer
Operating System Microsoft Windows XP Professional
DirectX 4.09.00.0904 (DirectX 9.0c)
Motherboard
CPU Type AMD Athlon 64, 2000 MHz (10 x 200) 3200+
Motherboard Name Unknown
Motherboard Chipset ATI Radeon Xpress 200, AMD Hammer
System Memory 2048 MB (PC3200 DDR SDRAM)
BIOS Type Award (10/14/05)
Display
Video Adapter NVIDIA GeForce 6600 (256 MB)
3D Accelerator nVIDIA GeForce 6600 PCI-E
Monitor ViewSonic A90-2 [19" CRT] (320003706212)
Multimedia
Audio Adapter ATI SB400 - AC'97 Audio Controller
Storage
Disk Drive SAMSUNG HD160JJ/P (160 GB, 7200 RPM, SATA-II)
Optical Drive TSSTcorp CD/DVDW TS-H552L (DVD+R9:2.4x, DVD+RW:16x/4x, DVD-RW:12x/4x, DVD-ROM:16x, CD:40x/32x/48x DVD+RW/DVD-RW)
SMART Hard Disks Status OK
This seemed like information that would help yall give me sound advice:
Field Value
CPU Properties
CPU Type AMD Athlon 64 3200+
CPU Alias Venice S939
CPU Stepping DH-E6
CPUID CPU Name AMD Athlon 64 Processor 3200+
CPUID Revision 00020FF2h
CPU Speed
CPU Clock 1989.39 MHz
CPU Multiplier 10.0x
CPU FSB 198.94 MHz (original: 200 MHz)
Memory Bus 198.94 MHz
CPU Cache
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard ID 10/14/2005-RS482-SB400-Amberine-00
Chipset Properties
Memory Timings 3-4-4-8 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules
DIMM1: Samsung M3 68L6523CUS-CCC 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM2: Samsung M3 68L6523CUS-CCC 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM3: Infineon AED660UD00-500B98X 512 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133 MHz)
DIMM4 512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
BIOS Properties
System BIOS Date 10/14/05
Video BIOS Date 07/29/05
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message Copyright 2005 by Hewlett-Packard Company Rev. 3.10
DMI BIOS Version 3.10
Graphics Processor Properties
Video Adapter nVIDIA GeForce 6600 PCI-E
GPU Code Name NV43 (PCI Express x16 10DE / 0141, Rev A2)
GPU Clock 301 MHz
Memory Clock 250 MHz
    • Let's see how long this lasts. In the end, it comes down to productivity lost because of workflow disruptions. It's not even a question of "which is better", rather how painful will it be to switch and it's hard enough for a single person to switch - imagine an entire city's bureaucracy. Remember, there are governmental system in the US that are still using 5.25" floppy disks... Having been involved in these kinds of swaps, I can tell you - it's never as easy as the fanbase thinks it is.
    • Right, saw it in the microsoft blog, wasn't mentioned in the article, thanks.
    • Multiple internal and external HDDs from Seagate, Western Digital are now at great prices by Fiza Ali Amazon and Newegg are currently offering substantial discounts on a wide selection of internal and external hard drives from Seagate and Western Digital, with prices reduced across multiple capacities. The 4TB WD Purple Surveillance is a 3.5-inch SATA III drive offering sustained transfer rates of up to 175MB/s. It employs Conventional Magnetic Recording (CMR) with a 256MB cache buffer. The drive operates reliably between 0°C and 65°C and can be stored in temperatures ranging from –40°C to 70°C. Western Digital backs this unit with a three-year limited warranty as well. 4TB WD Purple Surveillance Internal HDD: $84.41 (Amazon US) - 8% off The 6TB WD Blue is also a 3.5-inch internal hard drive that connects via SATA III (6Gb/s) and delivers sustained transfer rates of up to 185MB/s. It spins at 5,400 RPM, employs Conventional Magnetic Recording (CMR) technology, and features a 256MB cache buffer. The drive operates reliably in temperatures from 0°C to 60°C (with safe storage down to –40°C and up to 70°C). It is backed by a two-year limited manufacturer’s warranty. 6TB WD Blue PC Internal HDD: $99.99 (Amazon US) - 17% off The 10TB WD Red Pro NAS drive comes in a 3.5-inch form factor and connects via SATA III (6Gb/s). It sustains transfer speeds of up to 267MB/s thanks to its 7,200 RPM spindle and 512MB cache buffer, and employs Conventional Magnetic Recording (CMR) for reliable multi-drive operation. It operates safely between 0°C and 65°C, can be stored or transported in temperatures from –40°C to 70°C, and is covered by Western Digital’s five-year limited warranty. 10TB WD Red Pro NAS Internal HDD: $237.49 (Amazon US) - 15% off This WD Elements Desktop external hard drive offers a 14TB of storage via a USB 3.0 interface (up to 5Gb/s), using a USB Micro-B connector that is backward-compatible with USB 2.0. It operates reliably between 5°C and 35°C and can be stored in temperatures ranging from –20°C to 65°C. The drive is powered by an external adapter and carries a two-year limited warranty. 14TB WD Elements Desktop External HDD: $199.99 (Amazon US) - 31% off The 16TB Seagate Expansion Desktop external hard drive delivers vast storage capacity in a simple, plug-and-play design. USB 3.0 connectivity provides high-speed data transfer rates. Out of the box, the Expansion Desktop model is recognised automatically by Windows, macOS, and ChromeOS systems. If you wish to use Apple’s Time Machine backup utility, the drive must be reformatted to the HFS+ file system. 16TB Seagate Expansion Desktop External HDD: $229.99 (Newegg) - 30% off The 16TB WD Elements desktop external HDD connects via a USB 3.0 interface using a Micro-B cable (up to 5Gb/s.) The drive features plug-and-play functionality, working straight out of the box with Windows PCs. It operates reliably in ambient temperatures from 5°C to 35°C and can be stored in temperatures ranging from –20°C to 65°C. The drive comes with a 2-year limited warranty as well. 16TB WD Elements Desktop External HDD: $249.99 + $20 off promo code SAAET2384 = 229.99 (Newegg) The 16TB Seagate BarraCuda 3.5-inch internal HDD offers Multi-Tier Caching Technology (MTC) which balances NAND flash, DRAM, and media cache layers to accelerate application launches, reduce load times, and maintain consistently high sustained read/write speeds. The included Seagate DiscWizard software simplifies drive migration, cloning, partitioning, and backup tasks. The drive is covered by a two-year limited warranty. 16TB Seagate BarraCuda Internal HDD: $194.99 (Newegg) - 7% off The 20TB Seagate Exos X20 delivers an enterprise-class solution for high-density storage environments and data centres. It offers a sustained sequential transfer rate of up to 285MB/s and advanced caching to ensure low-latency, repeatable response times for data-intensive workloads. It further features 550TB/year workload rating, 2.5 million-hour mean time between failures (MTBF), and five-year limited warranty. PowerChoice and PowerBalance technologies allow administrators to tailor power consumption profiles for active and idle states, reducing energy costs and cooling requirements. Hardware-based AES-256 encryption, password protection, and Seagate Secure certification safeguard sensitive data. 20TB Seagate Exos X20 Internal HDD: $379 + $50 off promo code EPET2523 = $329.99 (Newegg) This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
    • It's all 1Password's fault for using it before anyone else. 🙃
    • Of course you would say that James. Mr everything Microsoft does is perfect. Mr who posts " I love it " on most articles regarding Microsoft. At least Firefox isn't a bloated pig that has an embarrassingly low market share given it's the default. Mr Microsoft evangelical James needs to learn some self awareness. It's embarrassing for you to criticize any browser give your worship of Edge.
    • Collaborator
      Mighty Pen went up a rank
      Collaborator
      emptyother earned a badge
      DarkWun earned a badge
    • Very Popular
      valkyr09 earned a badge
      Very Popular
      suprememobiles earned a badge
      178
      116
      Som
      109
