Just got a laptop and am wanting to create a simple network between my main pc and laptop
Ive got it setup as follows
Main pc connected to router via ethernet + printers connected to this
Laptop connected to router via Wifi
Ive setup the simple network with a guide ive found:
rename both computers and ensure they have the same "workgroup name"
do this by right click my computer properties "computer name" tab
at the bottom it says "to rename this computer or join a domain click change" - click change ensure workgroup is selected and both computers have the same name.
restart both when prompted to
then right click on the items you want to share ie c drive and printer and choose "sharing and security" click share this folder allow users to change my files.
once you have done that go in my computer , along the top click "tools" and "map network drive" choose a drive letter and explore to your other computers shared drive or folder
also share printers in the same way by adding printer > add network printer etc
I've done all of that on both machines and they can see each other..
On the main Pc when i go and map a network drive it sees the lappy and when i click the + sign i can see the folders im sharing on the lappy and once selected i can browse them
But when i go and do the same over on the lappy and map a network drive i can see the main pc but when i click the + sign next to it there's no folders or drives shown even though im sharing some files on the main machine.
Dont know if you understand that but cant seem to work it out.....Im using sygate on both and have the printer and file sharing option checked so i know that's OK
Anyone have any ideas as to what the problem could be at all?
Thanks in advance
https://www.neowin.net/forum/topic/529835-simple-network-problems/
Thanks in advance
Any ideas guys......cant seem to figure it out
Could it be somthing to do with services do you think.....As long ago i may of disabled a few on the main pc to speed things up
Thanks
  TurboTuna said:
Firstly: Wait atleast 24 hours to bump your thread.
If you browse your Main PC from your Main pc (i.e on your computer goto \\mainpc\ or whatever your computer is called) do you see the shared folders there?
Woops sorry about that....Just desperate to get it working
Yea when i type \\main i can see my shared files and printers
Just tried that still get the same
same services running on both machines.....Just redone the network wizard on both machines and disabled the firewalls on both machines but still get the same.
I haven't touched the router do you think it could have something to do with that...I'm running a Netgear DG384G router.
Thanks
Just tried in IE
on the main pc if i type \\laptop\Test i can see my test folder i have setup on the laptop
But if i go on the lappy and type \\Main\Test it comes up with the error 'windows cannot find \\main\test' check the spelling.....this pops up after a good few mins
Try running a login script when the computers load the will un-map then re-map the network share. I find that Windows does a terrible job of remembering the passwords on network computers. Same goes with Printers.
Try: http://www.computerperformance.co.uk/Logon...rive_rename.htm
or
Try: http://www.hftonline.com/forum/archive/index.php/t-4703.html
    • XnView Shell Extension 4.2.0 by Razvan Serea XnView Shell Extension is a powerful Windows Explorer add-on that enhances file management by providing quick image previews, thumbnails, and context menu tools without launching XnView. It supports over 500 image formats including RAW (CR2/NEF), WebP, HEIC, TIFF, and vector formats (PSD/SVG), allowing users to resize, convert, edit, and optimize images directly from the right-click menu. The lightweight integration streamlines workflows, enabling batch processing, metadata viewing (EXIF/IPTC), and seamless format conversion—ideal for photographers, designers, and casual users who need efficient file handling. Beyond basic previews, the extension offers advanced features like image rotation, format adjustments, and plugin support. Its intuitive interface ensures fast access to editing tools while maintaining system performance. XnView Shell Extension key features: 500+ Format Support – Opens and converts RAW, WebP, HEIC, TIFF, PSD, SVG, and more Batch Processing – Convert, resize, or rename multiple images at once Lossless JPEG Editing – Rotate, flip, and adjust without quality loss Metadata Preservation – Retains EXIF, IPTC, and XMP data during conversions Advanced Compression – Customize JPEG quality, PNG optimization, and WEBP settings Color Management – Handles ICC profiles, bit-depth (8/16/32-bit), and CMYK-to-RGB conversion PDF & GIF Support – Extract images from PDFs or create animated GIFs High-Speed Previews – Fast thumbnails and image previews in Windows Explorer Right-Click Actions – Quick access to resize, rotate, and convert without opening apps Plugin Extensibility – Add support for niche formats like DDS, HDR, or DICOM Download: XnShell 64-bit | Portable 64-bit | ~10.0 MB (Freeware) Download: XnShell 32-bit | Portable 32-bit | ~3.0 MB Links: XnView Shell Extension Home Page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
    • Another win for EU users? Ads in WhatsApp won't be coming this year by David Uzondu You might have heard that ads are making their way to WhatsApp after years of the company promising it would never happen. If you are in the EU (lucky you), you won't be seeing ads until 2026 at the earliest. A new report from POLITICO confirms that Meta, which owns the messaging service, has informed Ireland's privacy regulator that the new advertising model will not roll out in the European Union for quite some time, even as it appears elsewhere in the coming months. This is not some charitable act, of course. The delay gives European regulators time to scrutinize the plan, which involves using ad preferences from linked Facebook and Instagram accounts to target users. This situation follows a pattern of other "wins" for EU users, like the changes in iOS 17.4 that finally enabled sideloading. This opened the door for alternative app stores and the (temporary) return of games like Fortnite to iPhones in the region. Similarly, we are seeing Microsoft finally back off from shoving Edge down the throats of EU users, all thanks to the Digital Markets Act. This legislation has put pressure on big tech companies to operate more "fairly" within the bloc, leading to changes that users everywhere else can only dream of for now. These regulations are precisely what companies like Apple hate. Remember, Apple has issued a warning to Australia, telling the country not to follow Europe's lead on these matters because it would create massive security and privacy risks. Apple argues that its control over the ecosystem keeps users safe, so any attempt to break that open is dangerous. The Irish Data Protection Commission will be meeting with WhatsApp to discuss the matter further. According to Commissioner Des Hogan, they plan to discuss the ad model with other European data protection authorities to gather any collective concerns. Commissioner Dale Sunderland noted that discussions with the company are "still early days", and it is too soon to identify what, if any, specific "red line issues" might exist with Meta's advertising plans. For now, Europeans can continue using their ad-free messenger, while the rest of the world prepares for the inevitable.
    • Welcome to Neowin!
    • Idiots never imagine their insane actions troubling everyone.
    • Photo Variants 2.3 by Razvan Serea Photo Variants is an all-in-one photo editor for Windows. Quickly cull, import, and edit your images with powerful tools. Enjoy full layer support, precise retouching features, and a wide range of filters and color adjustments. Create multiple versions of a photo instantly with presets, or design from scratch using vector graphics and advanced editing options. Free for personal and commercial use. Photo Variants key Features: Advanced Adjustment Tools: Provides precise control over image modifications. ​ Extensive Filter Collection: Offers over 99 photo filters to apply various effects. ​ Animated Photo Effects: Enables the addition of dynamic elements to images. ​ Automatic Face Retouching: Includes features for enhancing facial features automatically. ​ Support for Multiple Formats: Compatible with over 100 graphic formats, including RAW and PSD files, allowing users to open, edit, and save in these formats. ​ Drawing and Transformation Tools: Facilitates freehand drawing, erasing, filling, cropping, resizing, rotating, and flipping images. Photo Variants supports a wide array of image formats, making it a versatile tool for all your editing needs. Key supported formats include: Raster Formats: .jpeg, .jpg, .png, .bmp, .gif, .tiff, .webp, .ico, .pcx. Camera RAW: .crw, .cr2, .dng, .nef, .raf, .arw, .orf, .x3f, .raw. Professional Formats: .psd, .ai, .svg, .tga, .pdf, .pcl. Specialized Formats: .dicom, .dcm, .heic, .heif, .avif, .exr, .dds. Other: .wmf, .emf, .xps, .jpeg2000 (.jp2)...etc... With support for these formats, Photo Variants offers seamless editing and flexibility for photographers, designers, and creatives. Photo Variants 2.3 changes: New effects for layers. New shapes and options for brushes. Download: Photo Variants 2.3 | 70.5 MB (Freeware) View: Photo Variants Home page | Screenshot Get alerted to all of our Software updates on Twitter at @NeowinSoftware
      Wayne Robinson earned a badge
      Karan Khanna earned a badge
      MikeK13 earned a badge
      OHI Accounting earned a badge
      170
