Mysql Problems
Hello
I am running Red Hat 8 with Apache & mySQL, i've got a copy of PremiumSoft MySQL Studio but when I enter my details, it says it cannot connect?
My Intranet site is running fine, and mySQL is running OK, the username and password are correct but mySQL Studio says it cannot connect as "root@10.44.16.191"
Can anyone help?
Thanks
Ben :)
https://www.neowin.net/forum/topic/53185-mysql-problems/
12 answers to this question
It may be a firewall/configuration error, try the following and let me know if it helps:
1) Create a custom firewall rule enabling port 3306 access by logging it as root and typing "lokkit" then restart iptables via "/etc/rc.d/init.d/iptables restart" or "/etc/rc.d/init.d/ipchains restart"
2) Modify /etc/rc.d/init.d/mysqld and replace '--skip-networking' with '--port=3306'
3) Start the daemon up via "$bindir/safe_mysqld --datadir=$datadir --pid-file=$pid_file --port=3306 &"
4) Log in as root to mysql (mysql -u root -p) and grant permissions to the database you want i.e. GRANT ALL PRIVILEGES ON dbname.* TO 'username'@'serverip' identified by 'password';
5) Restart MySQL and all should be good.
Good luck!
https://www.neowin.net/forum/topic/53185-mysql-problems/#findComment-529892
    • TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 is just $135 by Sayan Sen If you’re juggling gaming consoles, 4K streams and a growing roster of smart devices, the TP-Link Archer GXE75 Tri-Band AXE5400 Wi-Fi 6E Gaming Router is a good option to look at right now, considering the device is currently on sale at just $135 (purchase link under the specs table below). The Archer GXE75 promises up to 5.4 Gbps of throughput across three bands: 574 Mbps on 2.4 GHz, 2402 Mbps on 5 GHz and 2402 Mbps on 6 GHz (HE160 channels enabled). A 2.5 Gbps WAN/LAN port pairs with three 1 Gbps LAN ports and a USB 3.0 port for fast file sharing or printer access (purchase link down below). The quad-core CPU and 512 MB of RAM should help to handle multiple streams without bogging down, while MU-MIMO, OFDMA and 1024-QAM improve efficiency when several devices connect simultaneously. The router’s built-in Game Accelerator engine is said to automatically prioritize gaming packets (both wired and wireless), and TP-Link’s GPN (Gamers Private Network) acceleration can reduce packet loss for supported titles. HomeShield security brings firewall protection, device quarantining and parental controls. The technical specifications of the router are given below: Specification Details Wireless Standards IEEE 802.11ax 6 GHz; IEEE 802.11ax/ac/n/a 5 GHz; IEEE 802.11ax/n/g/b 2.4 GHz Wi-Fi Speeds 6 GHz: 2402 Mbps (802.11ax); 5 GHz: 2402 Mbps (802.11ax); 2.4 GHz: 574 Mbps (802.11ax) Spatial Streams 6 streams (tri-band OFDMA/MU-MIMO) Processor 1.7 GHz 64-bit Quad-Core CPU Memory 512 MB high-speed RAM Ethernet Ports 1× 2.5 Gbps WAN/LAN; 1× 1 Gbps WAN/LAN; 3× 1 Gbps LAN USB 1× USB 3.0 SuperSpeed port (up to 10× faster than USB 2.0) Antennas 4× high-performance external antennas with Beamforming Buttons Power On/Off; Reset; WPS/Wi-Fi; LED On/Off Working Modes Router Mode; Access Point Mode Security WPA, WPA2, WPA3, WPA/WPA2-Enterprise; SPI firewall; Access Control; IP/MAC binding; Application-layer gateway; HomeShield security suite VPN OpenVPN, PPTP, L2TP (server & client); WireGuard (server & client) Software & Services IPv4/IPv6; TP-Link HomeShield; EasyMesh; Parental controls; QoS by device; WAN types (Dynamic IP, Static IP, PPPoE, PPTP, L2TP); DDNS (TP-Link, NO-IP, DynDNS); auto firmware updates Gaming Features Game QoS boost; gaming-port priority; Gamers Private Network acceleration; game-port forwarding; real-time game panel with stats & RGB control Operating Environment 0 °C – 40 °C; 10 %– 90 % non-condensing humidity Get the TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 at the link below: TP-Link Tri-Band AXE5400 Wi-Fi 6E Gaming Router Archer GXE75 | EasyMesh, HomeShield: $159.99 + $25 off with coupon => $134.99 (Sold and Shipped by Amazon US This Amazon deal is US-specific and not available in other regions unless specified. If you don't like it or want to look at more options, check out the Amazon US deals page here. Get Prime (SNAP), Prime Video, Audible Plus or Kindle / Music Unlimited. Free for 30 days. As an Amazon Associate, we earn from qualifying purchases.
    • Oh no... here we go again. Tha same sh*t that happaned to Mail & Calendar...
    • I too have worked with pro gear for decades and so I found the interface to be unintuitive from both the pro and casual side (a rare "accomplishment" by what are obviously otherwise skilled coders, hehe). I eventually got it to work, thanks for offering, but I found other compatibility issues with my own use case, so I just dropped it entirely. Right now, I just use an analog line out/line in approach which works as expected across all usage scenarios. With both machines on the same power block/outlet, I'm not getting any analog hum or hiss. My next step will be to try the updated Multiplicity 4 when a bug, addressing this very issue unfortunately, is resolved. Knowing Stardock, that could be tomorrow or five years from now, so I check back every few months to see it it's fixed and I want to upgrade. Again, thanks for offering to help.
    • We recognize that performance can use some improvements, and we continue to work on improving it. However, it's worth noting that massive performance improvements don't happen overnight, they take a lot of work and effort, and in most cases, the improvements are more noticeable when you compare across several updates. That said, Files is open-source and everyone is invited to help with these efforts 🙂
    • A lot of effort has gone into improving stability and Files Preview now has a 99% crash free rate. These improvements will make their way to Files Stable when v4 is released later this year. If you're still experiencing issues, please report them on GitHub or Discord so we can track them properly.
      Snake Doc went up a rank
      nobody9 earned a badge
      Ricky Chan earned a badge
      leoniDAM earned a badge
      Ian_ earned a badge
      137
      115
