Problems in sharing net connection with a symbian phone
Hi,
I recently bought Nokia E50, a Symbian 9.1 3rd edition phone. I read on quite a few sites that I can share my net connection with my mobile through bluetooth by installing Gnubox on my Symbian phone. I referred to a couple of guides. http://howto.helpero.com/howto/Share-The-I...ia-6600_18.html and http://ruk.ca/w/index.php/Sharing_an_OS_X_...Series_60_Phone
I use a PPPOE connection on my Mac Mini that runs Mac OS 10.4.8.
The first step in both guides is to pair my phone with my Mac and set up a serial port. I've done that. However, I just can't connect to the internet from my phone using both the guides.
Method 1 i.e. http://ruk.ca/w/index.php/Sharing_an_OS_X_...Series_60_Phone says that I need to assign a private IP to my phone similar to that of my Mac. However, the difference here is that I use a PPPOE connection and therefore, my Mac's ethernet connection does not have a private IP.
The method also asks to enter the following command in Terminal.
sudo /usr/sbin/pppd /dev/tty.Bt 115200 noauth local passive proxyarp asyncmap 0 silent persist?:192.168.1.95
What IP address should I give, to the phone, in my case?
In another step, it says
'Under Options > Advanced settings > Name servers for this connection(on the phone), enter the IP address of your primary name server (i.e. the name server you're using on your Mac)'.
My mac's ethernet PPPoE connection does not have any IP address/name server. What should I do in this case?
Method 2>: The Apple Script that is attached is faulty.
do shell script "sudo /usr/sbin/pppd /dev/tty.bluetooth-pda-sync-port 115200 noauth local passive proxyarp asyncmap 0 silent persist :10.0.1.201 &" with administrator privileges
do shell script "sudo /usr/sbin/sysctl -w net.inet.ip.forwarding=1"
do shell script "sudo /usr/sbin/natd -same_ports -use_sockets -log -deny_incoming -interface en0"
So, I tried entering the commands in Terminal manually.
I get this error when I pass the above command:
natd: en0: cannot get interface address
Can some one Please help me with this? I only want to know how to get OS X to share the ethernet connection with the phone(/dev/tty.Bt)!
    • Both a game adaptation and it's on Amazon I'll set my hopes low
    • You shut your mouth you young fart, that was just a few years ago, lol.
    • Good effort, but unfortunately not very useful in the real world, since it doesn't support UEFI - which is a major drawback. More than that, most PCs these days have Secure Boot enabled by default, so unless you're tech savvy, the average joe is not going to disable Secure Boot - which means automated Windows > Linux migration programs like this will not work. And if you're tech savvy enough to know how to disable Secure Boot, then you're tech savvy enough to just flash a USB drive and install Linux the usual way - after all, the actual installation process is just point-and-click. So I don't see a use case here to be honest, especially considering the lack of UEFI support - especially when you consider that more and more Linux distros are completely dropping BIOS support (eg Fedora dropped it back in 2022). So this program is a bit too late to the party.
    • I agree with open rights group that the age check companies should be regulated but action does need to be taken imo, they may be called irresponsible parents but the fact is that many don't know how to set up blocks. Why should kids suffer because their parents don't know something? I think the UK has always been a bit like this. We don't say healthcare is your responsibility, we tax everyone and make people register with the NHS. We also don't expect everyone to brush their teeth to maintain dental health, we just put fluoride in their water assuming people aren't brushing enough, because some probably aren't or aren't doing it properly. In general, this way of doing things works.
      Falcon.ai earned a badge
      EYEREX earned a badge
      Electronic Person earned a badge
      CyberCeps666 earned a badge
      165
      123
