Removing "Beep" when adjusting Volume Control
I am using a laptop, HP Pavilion. Whenever I shift the Volume Control bar, there will be a "Beep" sound produced. I find it very irritating for everytime I change the volume, there will be very loud Beep sound that I cannot off. Anyway to deactivate this beep?
Heh, I guess that's a way to do it too :)
Anyway, it seems it's the PC speaker "beep" you have a problem with, and not a "beep" from the sound card.
The PC speaker beep comes up there because I believe you have "Default Beep" set to none.
Set "Default Beep" to an actual sound file, then adjust your sound card volume and you won't have something as annoying anymore. Another option would be to set it to a silent sound. But I guess disabling the PC speaker device itself like you did is another way, hehe.
