I am in the Windows Home Server beta and am trying to set up the remote access feature. In the documentation, it says to forward some ports to the home server.
According to the documentation, I should be able to type in my public IP and be able to access the server over the Internet via web browser.
My setup is this: Internet => (Westell 6100 modem) => (Netgear WGT624v3 wireless router) => server and other networked PCs
I have the modem (gateway IP: 192.168.1.1) forwarding the ports to the wireless router (static Internet IP: 192.168.1.47, LAN IP: 192.168.10.1), which is forwarding the ports to the server (static IP: 192.168.10.4).
I can successfully forward the ports if the server is directly connected to the Westell modem, but when I add the Netgear wireless router (changing the settings, of course), the port forwarding fails.
I have the latest firmware and have set up the port forwarding for each router according to the documentation.
Here is a screenshot of the Westell settings:
Here is a screenshot of the Internet IP settings:
And here is a screenshot of the forwarding settings:
Any help is appreciated!
Edited by NateB1
https://www.neowin.net/forum/topic/539810-double-port-forwarding-problem/
okay first question is what type of internet do you have? I'm assuming DSL because the type of modem. post what your ISP is and I'll try to give you some more information.
what you're probably going to want to do is put the modem into "bridge" mode but don't do it until you know 1) If you're DSL/cable/what. 2) What your connection type is: DHCP or PPPoE.
Edited by KHaKi-
I have DSL with Verizon, My connection is DHCP, and the modem is already in bridged mode.
  Ricky S. said:
Your internet IP settings are wrong, it should be set to Dymanic unless you pay for a static IP in which case that's still not a external routable address.
The "Internet IP" setting on the wireless router is what the Westell router sees. The public IP is managed by the Westell modem.
  thexxend said:
Your first problem is that your modem is actually a modem/router... I would suggest seeing if it has a "DMZ" feature and point it to the ip of the wireless router... if it does than just put the settings in the wireless router and your gold...
I searched though all the settings and couldn't find the "DMZ" setting.
I checked Verizon's documentation, but couldn't find anything there either
call verizon online dsl technical support 1-800-567-6789. we're open 24 hours a day 7 days a week. :x :x :x but if you do call they're probably going to RTV you to netgear >_>
OK, I solved it. When I first looked at the VC settings to make sure my router was in "bridge" mode, the summary said it was "Bridged".
Upon further investigation, I clicked "edit" to edit the settings, and I noticed it said "routed bridge". I changed it to "bridge", logged on to my wireless router, and entered the IP, gateway, and DNS addresses found in the "routed bridge" settings on the Westell modem.
Everything works perfectly now!
Thanks for the help!
Um so you setup your wireless router internet port as static? Is that what your internet connetion is - static IP? If not its quite possible in the future when your ISPs dhcp servers hand out that IP.. your connection will go down.
Once you change your westell into bridge mode -- you should setup your wireless router as whatever your connection type is.. if your suppose to get an IP from your isp using dhcp.. then then is how you should setup your wireless routers wan port.
You have 2 options here, you either turn your westell into a "JUST" a modem -- which it sounds like you did. Or you use your wireless router as an access point, and allow your westell to be your NAT device and where you port forward, etc.
http://www.dslwebserver.com/main/wireless-...cess-point.html
How to Use a Wireless Router as a Wireless Access Point
If you did turn your westell into JUST a modem - great, I would just make sure your not using a static public address, when its suppose to be dhcp? On your wireless routers internet port. If its not a public address - then your still double natting, and even though you might have gotten a forward to work -- its still not the optimal setup.
    • Intel's new GPU driver adds support for FBC: Firebreak, Stellar Blade, and more by Taras Buria Intel has released a new non-WHQL driver under version 32.0.101.6876. The update brings support and optimizations for four games and a single fix for visual artifacts that appear in certain situations. Here is the list of newly-supported games in driver 32.0.101.6876 on systems with Intel Arc B-Series, A-Series, and Intel Core Ultra with built-in Arc graphics: FBC: Firebreak Rematch Stellar Blade Tom Clancy's Rainbow Six Siege X There is also a single bug fixed in today's release: Intermittent visual artifacts may appear in certain usage scenarios. Known issues remain the same as in the latest WHQL release, except for a new bug that causes audio glitches on handheld devices: Certain handheld devices may experience audio glitches and lower-than-expected performance while audio is playing. You can mitigate the problem by following a guide that Intel published on the official forum. It requires reinstalling the graphics and NPU drivers on the affected systems. A proper fix will be available in a future driver update. You can install Intel 32.0.101.6876 non-WHQL driver on PCs with 64-bit Windows 10 and Windows 11 with the following graphics products from Intel: Discrete GPUs Integrated GPUs Intel Arc A-Series (Alchemist) Intel Arc B-Series (Battlemage) Intel Iris Xe Discrete Graphics (DG1) Intel Core Ultra Series 2 (Lunar Lake and Arrow Lake) Intel Core Ultra (Meteor Lake) Intel Core 14th Gen (Raptor Lake Refresh) Intel Core 13th Gen (Raptor Lake) Intel Core 12th Gen (Alder Lake) Intel Core 11th Gen (Tiger Lake) You can download the driver from the official website here. Full release notes are available here (PDF). Keep in mind that this is a non-WHQL driver, which means it could be less stable than certified WHQL drivers.
    • He did give it away in 2008, well actually he gave away half of his fortune. He was open at the time that part of the reason he was doing it was that he was accumulating wealth faster than he could conceive of spending it
    • ooof! made me wince when i saw where the stand connected!
    • Microsoft Edge.  The vertical tabs are a must have feature for me.
    • It does when you're a software developer and you have to provide supports for these people.
      jbatch earned a badge
      Leonard grant earned a badge
      portacnb1 earned a badge
      m10d earned a badge
      snowy owl
      158
      146
      131
