[Java] Command for running...
I have done all the programming and the code works perfectly. I know this because it works through Eclipse [using a plugin]. Therefore, I wrote commands by going through the Run settings in Eclipse.
JDBCClient
java -cp D:\copyarea\DS\workspace\jdbc-client\bin;D:\copyarea\DS\workspace\jdbc-common\bin -Djava.rmi.server.codebase=file://D:/copyarea/DS/workspace/jdbc-client/bin;file://D:/copyarea/DS/workspace/jdbc-common/bin -Djava.security.policy=D:\copyarea\DS\workspace\jdbc-client\security.policy mine.rmi.jdbc.client.JDBCClient
JDBCServer
java -cp D:\copyarea\DS\workspace\jdbc-server\bin;D:\copyarea\DS\workspace\jdbc-common\bin -Djava.rmi.server.codebase=file://D:/copyarea/DS/workspace/jdbc-server/bin;file://D:/copyarea/DS/workspace/jdbc-common/bin -Djava.security.policy=D:\copyarea\DS\workspace\jdbc-server\security.policy mine.rmi.jdbc.server.JDBCServerImpl
Believe me all the paths are correct. After I start the rmiregistry, when I try to run the 2nd command (for starting the server), it gives me the following exception:
java.security.AccessControlException: access denied (java.io.FilePermission \\D\
copyarea\DS\workspace\jdbc-server\bin;file:\D:\copyarea\DS\workspace\jdbc-common
\bin read)
		at java.security.AccessControlContext.checkPermission(AccessControlConte
xt.java:264)
		at java.security.AccessController.checkPermission(AccessController.java:
427)
		at java.lang.SecurityManager.checkPermission(SecurityManager.java:532)
		at java.lang.SecurityManager.checkRead(SecurityManager.java:871)
		at java.io.File.exists(File.java:700)
		at sun.net.www.protocol.file.Handler.openConnection(Handler.java:80)
		at sun.net.www.protocol.file.Handler.openConnection(Handler.java:55)
		at java.net.URL.openConnection(URL.java:943)
		at sun.rmi.server.LoaderHandler.addPermissionsForURLs(LoaderHandler.java
:1020)
		at sun.rmi.server.LoaderHandler.access$300(LoaderHandler.java:52)
		at sun.rmi.server.LoaderHandler$Loader.<init>(LoaderHandler.java:1108)
		at sun.rmi.server.LoaderHandler$Loader.<init>(LoaderHandler.java:1089)
		at sun.rmi.server.LoaderHandler$1.run(LoaderHandler.java:861)
		at java.security.AccessController.doPrivileged(Native Method)
		at sun.rmi.server.LoaderHandler.lookupLoader(LoaderHandler.java:858)
		at sun.rmi.server.LoaderHandler.loadClass(LoaderHandler.java:381)
		at sun.rmi.server.LoaderHandler.loadClass(LoaderHandler.java:165)
		at java.rmi.server.RMIClassLoader$2.loadClass(RMIClassLoader.java:620)
		at java.rmi.server.RMIClassLoader.loadClass(RMIClassLoader.java:247)
		at sun.rmi.server.MarshalInputStream.resolveClass(MarshalInputStream.jav
a:197)
		at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:153
8)
		at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1460)
		at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1
693)
		at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1299)
		at java.io.ObjectInputStream.readObject(ObjectInputStream.java:339)
		at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
		at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef.java:375
		at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:240)
		at sun.rmi.transport.Transport$1.run(Transport.java:153)
		at sun.rmi.transport.Transport.serviceCall(Transport.java:149)
		at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:4
60)
		at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport
.java:701)
		at java.lang.Thread.run(Thread.java:595)
		at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(Unknow
n Source)
		at sun.rmi.transport.StreamRemoteCall.executeCall(Unknown Source)
		at sun.rmi.server.UnicastRef.invoke(Unknown Source)
		at sun.rmi.registry.RegistryImpl_Stub.bind(Unknown Source)
		at mine.rmi.jdbc.server.JDBCServerImpl.main(JDBCServerImpl.java:66)
I have no idea what's going on, because I can run the server just fine through Eclipse and the client program can be run from either: command prompt or Eclipse.
I'll be grateful for any help.
https://www.neowin.net/forum/topic/543626-java-command-for-running/
1 answer to this question
    • Windows 7 its the peak of windows desktop experience, it felt polished, it was CONSISTENT, the UI was not something made to ###### people off it was more functional and productive because everything felt like a improvement. Windows 8 was horrible they did fix a little with 8.1 but the thing its that in usability it was the same as 7 you can avoid all the metro stuff, you don't need to use the cripple setting or metro stuff, for me it was bearable because it can be customized and you can make it like 7 (sure you waste time setting stuff) even if you needed a third party app. And there are serious performance improvement over 7 faster startup, Windows 10 was ok too nothing felt out of place and the start menu was usable it was filled with bloat but as usual you can remove it, what i really hated about 10 at that time it have worse windows update, you cant customize what update to install and the privacy and telemetry is horrible again it was bearable even but w11, not only they double down on things that i seriously hate on 10 like the bloat, they force changes that make no sense, make an worse start menu, worse context menu, worse task bar. force microsoft account. When i tried w10 iot enterprise LTSC on a ancient laptop, i felt that it was a throwback of what OLD windows should be a normal desktop OS with only the basics and you put the rest it was fast fluid functional, no nagging, its a productive, spend less time setting up the OS the way i want it. every windows after 7 its making it worse for me because i have to spend more time setting up
    • https://filepilot.tech/ File Pilot is a whole lot faster and offers a lot of the same features. Has a free beta available, but it looks like it's going to be a paid app in the future.
    • 24H2 was absolutely plagued with stability and compatibility problems, many of which are still not solved. You don't have to take my word for that either, given that Microsoft have an official know issues page available. Games using older versions of Easy Anti-Cheat still cause 24H2 to lock up and/or BSOD, and there's still a compatbility hold on upgrades if you have them installed as a result. Maybe 25H2 will be less of a dumpster fire, but I wouldn't count on it given Microsoft's recent track record.
    • No I don't also get my news for one source. Have you considered that maybe I just don't care about tech enough to spend time reading multiple sources? Anyway my website preferences are way off topic.
    • The bloat on windows after 7 was acceptable, but 11 its even worse than chinese android phone makers, because at least they can remove the ads or apps, but w11 shove you bloat with no option to remove it, it seems that 25h2 will fix that
      MIghty Haul earned a badge
    • Collaborator
      KD2004 earned a badge
      Collaborator
      ataho31016 earned a badge
      Delahenty Machinery earned a badge
      140
      127
