I just installed ubuntu6.10 and beryl on a PC and I was fiddling around with the effects in beryl, and i enabled the "blur" plugin effect. Ubuntu then froze, and now it freezes every time I login. Am still a novice with Linux, so how do I go about fixing this? What's the best thing to do?
PS: Has anyone found Beryl 0.2 unstable?? I found the previous version on ubuntu 6.06 much quicker and I didn't have a crashing with the blur effect then :wacko:
https://www.neowin.net/forum/topic/552120-ubuntu-berylnvidia-problem/
Yes beryl is unstable and just delete your hidden beryl files/directories in your home folder. This should reset all your settings.
Anyway Beryl as you know it is dead as it is merging with Compiz which in my experience is much more stable although a little bit tricky to configure.
You can use ctrl+alt+backspace to kill the X server if it locks up and return to the terminal. Login with your user priviledges and sudo apt-get remove beryl to uninstall it or use a text editor like nano to edit the beryl configuration files to restore them to working order. You can also use ctrl+alt+F1 or any option of F1-F6 for access to multiple terminal windows. Your X server will be operating on F7.
OK so if I want to try and edit the beryl configuration files, what commands should i be using?? I really have no clue, ecept it has something to do with sudo... :unsure:
  • 2 weeks later...
Beryl is a fork of compiz, any merging will be a benefit more to compiz than beryl. It is very stable, has many plugins, an excellent theme application, and is much much more customizable than the compiz that IMO hasn't progressed much since it's first conception with xgl. Beryl can also be run natively without xgl if you run the latest nvidia drivers and xorg 7.1>.
Beryl
Beryl
I know what is Beryl as I used it since it was compiz-quinn until I changed to ArchLinux (january). It's not stable neither emerald is excellent and I know this because I used it and reported a few bugs that were never fixed and won't be fixed (they even are rewriting the thing from scratch).
In my case Compiz is 10x faster than Beryl and it never locks up my gnome-session when I login (as beryl).
And if Compiz wouldn't have progressed since it's first conception then why did Beryl developers keep porting every change from Compiz core to Beryl?
Anyway the merge is on it's way and Beryl as you know it right now is dead, at least for the time being.
    • Back to School 2025 Nvidia gaming laptop deals list from Gigabyte, MSI and Acer by Sayan Sen The Back To School sales for 2025 are currently live with several laptops from MSI, Gigabyte, and Acer. These are gaming as well as studio laptops powered by Nvidia GPUs. A wide range of laptops ranging from $700 all the way up to $3000 are available. MSI has the most devices available while Gigabyte also has plenty in the list to choose from. Acer laptops and its trusty Predator machines are there too. Check the full list of discounts below: GIGABYTE - AORUS MASTER 16 Gaming Laptop - 240Hz 2560x1600 OLED - NVIDIA GeForce RTX 5090 - Intel Core Ultra 9 275HX - 2TB SSD with 32GB DDR5 RAM - Windows 11 Home AD (AORUS MASTER 16 BZHC6USE65SH) + Intel CPU Spring Bundle worth $159.99 for free: $3899.99 + $50 rebate => $3849.99 (Shipped and Sold by Newegg US) MSI - 18" GeForce RTX 5080 Laptop GPU - Intel Core Ultra 9 285HX - 64GB DDR5 6400MHz Memory - 4 TB SSD - Windows 11 Home - Gaming Laptop - 120 Hz Mini LED (Raider 18 HX AI A2XWIG-014US ) + Intel CPU Spring Bundle worth $159.99 for free: $3779.99 (Shipped and Sold by Newegg US) MSI Vector - 16" GeForce RTX 5080 Laptop GPU - Intel Core Ultra 9 275HX - 32GB Memory - 2 TB SSD - Windows 11 Pro - Gaming Laptop - 240 Hz (Vector 16 HX AI A2XWIG-058US ) + Intel CPU Spring Bundle worth $159.99 for free: $2799.99 (Shipped and Sold by Newegg US) MSI - 16" GeForce RTX 5070 Ti Laptop GPU - Intel Core Ultra 9 275HX - 32GB Memory - 2 TB SSD - Windows 11 Pro - Gaming Laptop - 240 Hz (Vector 16 HX AI A2XWHG-060US ) + Intel CPU Spring Bundle worth $159.99 for free: $2549.99 (Shipped and Sold by Newegg US) MSI Summit Pro 16 16" Touchscreen Laptop Intel Ultra 7 255H GeForce RTX 4050 32GB Memory 1 TB NVMe SSD Windows 11 Home Summit Pro 16 AI A2HVETG-074US: $1349.99 (Shipped and Sold by Newegg US) Aorus - 16" GeForce RTX 4060 Laptop GPU - Intel Core i7-13700HX - 16GB Memory - 1 TB PCIe SSD - Windows 11 Home 64-bit - Gaming Laptop - 240 Hz (16 BKF-73US654SH ): $1199.99 (Shipped and Sold by Newegg US) MSI Creator M14 14” 2.8K Display Creator Laptop: Intel Core i7-13620H, NVIDIA Geforce RTX 4050, 16GB DDR5, 1TB NVMe SSD, Cooler Boost, Win 11: Black A13VE-083US: $999.99 (Shipped and Sold by Amazon US) MSI Thin A15 B7V Thin A15 B7VE-214US 15.6" Gaming Notebook - Full HD - AMD Ryzen 7 7735HS - 16 GB - 512 GB SSD - Cosmos Gray - AMD Chip - 1920 x 1080 - Windows 11 - NVIDIA GeForce RTX 4050: $929.00 (Shipped and Sold by Newegg US) MSI Thin A15 B7U Thin A15 B7UC-473US 15.6" Gaming Notebook - Full HD - AMD Ryzen 5 7535HS - 16 GB - 512 GB SSD - Black - AMD Chip - 1920 x 1080 - Windows 11 Home - NVIDIA GeForce RTX 3050: $909.00 (Shipped and Sold by Newegg US) MSI Cyborg - 15.6" GeForce RTX 4050 Laptop GPU - Intel i7-13620H - 16GB Memory - 512 GB SSD - Windows 11 Home - Gaming Laptops - 144 Hz IPS (A13VE-218US ): $849.99 (Shipped and Sold by Newegg US) Acer Nitro V - 15.6" GeForce RTX 4050 Laptop GPU - Intel Core i7-13620H - 16GB Memory - 512 GB PCIe SSD - Windows 11 Home - 144 Hz IPS - Gaming Laptop with Acer Gaming Controller (ANV15-51-717H ): $839.99 (Shipped and Sold by Newegg US) Aorus - 15.6" GeForce RTX 4050 Laptop GPU - Intel Core i5-12500H - 8GB Memory - 512 GB PCIe SSD - Windows 11 Home 64-bit - Gaming Laptop - 360 Hz (15 9MF-E2US583SH ): $699.99 (Shipped and Sold by Newegg US) As an Amazon Associate and Newegg Affiliate Partner, we earn from qualifying purchases.
    • I'd say this is hardly news. A GUI wrapper is not exactly some grand accomplishment. Even ClamAV itself is of questionable use. I suppose it lets you check the box on an audit questionnaire that a server has virus protection. But Linux has always been a more difficult target for malware because of the wide variety of distros, library versions, etc. And also the fact that it has a much smaller user base consisting of users who are generally more knowledgeable.
    • Privacy nightmare... And, yes, I know, there's an On/Off toggle. But like Edward Snowden once said : "Where there's an On/Off toggle, there's always a way to turn it on." 😉 Microsoft is also working on letting Copilot tap into your history and credentials so that it can better understand context and perform actions on your behalf
    • Looks like "LoucheBear" should be renamed "DoucheBear". Ignorant ######.
    • The dev is a snowflake for deciding that a project he’s not getting paid to do isn’t worth the attacks? Interesting.
      NeoWeen earned a badge
      Doreen768 earned a badge
      James_kobe earned a badge
      167
      121
