First off, I am new here, and am very sorry if this is a dumb question. I wasn't getting any answers anywhere else, and figured this would be the best place to ask!
I want to install uxtheme multipatcher, but before I do, I want to know if it will work with my system.
-I am running Windows XP SP2 build 2600
-I have been told that with SP2 build 2600, uxtheme multipatcher can cause system instability
-if so, define "system instability"
-Most importantly, if uxtheme multipatcher doesn't work/I don't like it, can I always do a system restore (to an earlier time) and regain my old default themes?
Thanks for any help!
https://www.neowin.net/forum/topic/560982-uxtheme-multipatcher-help/
1: Ok I understand .
2: I have no idea.
3: System instability means crashing or hanging of your system whenever possible ( Or at a fixed time, for eg. Startup ) .
4. Yes you can system restore if you have set a restore point. But I really don't think that it would replace system files :| . Well I'm not the expert , I suggest you wait for another opinion :)
1. yes, it will work.
2. no, it does not cause instability.
3. see 2.
4. you don't need to do a restore and it won't affect your themes. all the patcher does is replace the default uxtheme.dll file with an unlocked one. that's it.
read more:
https://www.neowin.net/forum/index.php?showtopic=140707
https://www.neowin.net/forum/index.php?showtopic=339820
Well, I tried installing it on my laptop, which had about 30 mins. of battery left. On startup, though, it WENT OFF (All I saw was the company splash screen and then black) and even when I plugged it in it wouldn't start up. Finally, I had to pop the battery out, wait a few minutes, and then pop it back in. It never installed and I think I kind of lost my nerve -_-'
It works just fine. I've been using it pretty much ever since I started using XP and themes, which was a while later... die-hard classic fan for a long time. ;)
But I digress, the patcher does nothing more than replace one DLL file. If it SHOULD fail all that will happen is that you won't be able to view the theme settings in the "Display Properties" dialog. That is all. I tried replacing it manually once with a copy meant for another build, and it didn't work.
Hey. I tried installing it again. Everything went fine (as the installation initiated, the "XP" theme went away and a "classic" looking white theme appeared, as it did last time), but when it went to restart, an update started and I couldn't stop it. It restarted, I logged on, and it was back to the old XP theme. Not sure if it worked, I tried using a theme I found at Deviantart:
http://www.deviantart.com/deviation/504219...h+age_scale%3A5
I clicked on the Windows Visual Style file "Zune", and besides opening "Properties" to see the 3 XP and classic themes, nothing happened. So I went into the folder named "shell" and clicked on one of the Windows Shell Style Resource Dll files, when I got a warning about the dangers of messing around with dll files, ending with "if you wish to continue, click "Open With..." If not, click "cancel""
I clicked cancel.
Is there any way I can check to see if the multipatcher installed?
  KierenCB said:
Oh, wait, I have to install the files into C:\Windows\Resources\Themes, right?
Yup. Hierarchy goes as follows:
C:\WINDOWS\Resources\Themes\Themename\Themename.msstyles
C:\WINDOWS\Resources\Themes\Themename\shell\
Keep in mind that Themename should remain the same in the directory and also the msstyles file.
Okay. I made a file in C:\WINDOWS\Resources\Themes\ called "Blue" after the "Blue" zune theme; I moved the "blue" folder and .dll file there. I went to properties/appearance, nothing happened.
Then I moved the Windows Visual Style file "Zune: to C:\WINDOWS\Resources\Themes\ (where Luna Windows Visual Style file is) and nothing happened.
But, when I click on the "Windows Shell Style Resource Dll file" should I click cancel or open with... or, if it patched properly, would it automatically open the properties/appearance window? Oi.
Am I the only person who uses Universal UXTheme Patcher v2.1? Installation is as simple as it gets and Ive havent come across a style that conflicts with it.
Here is a working link for it:
http://www.mediafire.com/?6thtnhzjdy4
Give it a shot, no muss no fuss.
    • Because Win7 was beautiful, much faster and more functional than XP. Win10 (glossing over 8 as many do) was slightly faster in some cases, more functional in some cases, but some people such as myself hated how it looked and decided it wasn't worth the upgrade. Some people liked (or were ok with) the look, and thus it is a good upgrade. Win11 is like 10, but is less functional between key features being removed and constant bugs/crashes either due to updates, or just things that were never patched. It literally has nothing going for it, and I use it every day at work so I'm quite familiar with it.
    • I switched my mom from Chrome to Firefox and she had a serious meltdown. She even managed to figure out how to reinstall Chrome, which really surprised me. What finally got her to switch was Chrome no longer being supported on Win7 and me putting a Chrome skin on FF, and setting it up identically.
    • Feels very much like most other gnome based Linux distros. There is minimal amounts that are influenced by Windows 11, maybe just enough to make people who are switching comfortable enough with the idea. As far as I can tell its mainly just turning the 'taskbar' panel as a 100% sized static panel, rather than the default dynamic sized. Turning it from the Mac OS Dock into the Windows taskbar. The Arc Menu - that I assume you're taking not with from the screenshots, is indeed the Windows 11 style one, but it has lots of other options too, from the more traditional gnome, Windows 7 etc. Still free to install what ever Window Manager you want once you're comfortable enough with Linux though.
    • Wow, and here I'm still happily using 1080p...
    • Added an extra filter to Fail2Ban.  I thought about just adding this to my existing aibots filter, but for the time being I'm keeping it separate because it's "possible" real humans may trigger this one so as long as it doesn't start filling my inbox I'd like to get notified about these so I can adjust it as necessary in the future. I'm still holding close to 10k unique IP addresses at any given time that have been banned via the "aibots" filter that looks for certain user agent strings of known AI scrapers.  However, I've been getting an increasing amount of traffic trying to scrape the site with sanitized user agent strings that just look like normal web browsers, however... Because I enabled authentication I can now see that they're racking up lots of 401 (unauthorized) responses in the Apache "access.log" file, but they're not triggering anything in the Apache "error.log" file, which is where failed attempts to log in would appear.  Basically, if an actual human tried to log in with an invalid username and password they don't immediately go into "access.log" as a 401, they go into "error.log" with a status message such as "user FOO not found".  The only way to trigger a 401 simply by visiting the site, as far as I'm aware, is to hit "Cancel" on the login prompt, or otherwise try to access files directly without properly authenticating. So, given the fact I'm getting a few thousand 401 errors a day from sanitized user agent strings that don't show up in "error.log", which means no attempt at logging in properly, I added another jail/filter set to Fail2Ban to immediately ban anybody who triggers a 401.  This feels a bit nuclear so I may need to adjust it in the future, but as far as I'm aware so far no real humans are being inconvenienced so all I'm doing is wasting the time of some AI scraper bots. Example log entry 61.170.149.70 - - [25/Jun/2025:20:01:04 -0400] "GET /content/mdwiki_en_all_maxi_2024-06/A/Neuroregeneration HTTP/1.1" 401 3287 "https://kiwix.marcusadams.me/content/mdwiki_en_all_maxi_2024-06/A/Neuroregeneration" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36 Edg/114.0.1823.43" Contents of /etc/fail2ban/filter.d/apache-401repeat.conf #Fail2Ban filter for bots and scrapers that try to access #files directly without entering credentials for apache2-auth #and therefore trigger lots of 401 errors without triggering #the apache-auth jail. # #Marcus Dean Adams [Definition] failregex = ^<HOST> .+\" 401 \d+ .*$ Contents of /etc/fail2ban/jail.d/apache-401repeat.local [apache-401repeat] enabled = true ignoreip = 10.1.1.1 port = 80,443 filter = apache-401repeat maxretry = 1 bantime = 672h findtime = 10m logpath = /var/log/apache2/access.log Oh, and all this traffic is AFTER I explicitly banned Alibaba's IP ranges that were absolutely blowing me up day and night. Observation; two of the IP addresses that have triggered this jail in the 30 or so minutes since I turned it on were owned by Microsoft.  Wonder if they're doing their own AI scraping/probing, or if that's just an Azure VM owned by somebody else.
    • Rising Star
      Phillip0web went up a rank
      Rising Star
      Epaminombas earned a badge
      Bert Fershner earned a badge
      ChrisOdinUK earned a badge
      Steviant earned a badge
      175
      Som
      138
