Counter Strike Source Serious problem
How is everyone doing..one of my mates is having a strange problem when playing CSS, every 5 or 10 minutes CCS would crash with message
ENGINE ERROR. failed to lock index buffer in CMeshDX8:LockIndexBuffer"
i have looked into google couldn't find anything that could solve this issue.
Specs
Win xp Pro sp 2
Intel P4 3.60ghz presscott
2 gig of ram
Ati xt800xt 256mb
2 maxtors on raid0
he never head this issue before, can someone suggest anything or know anything about this....!
cheers mates
  Code.Red said:
Open CS:S, go in console and tell me what your mat_dxlevel variable is set to.
Also, what resolution are you playing at?
Do you have the latest drivers for your ATI card?
mat_dxlevel is set to 90
playing on 1280x1024
i do have the latest drivers
  M.F.D.K said:
ok i will give that a try, just wondering it can't be that the graphic card is dying away can it....?
Nah, if the card is dying you'll get artifacts and wierd crap - or your PC just won't work. It would'nt do any harm though to check the temps of your card though.
