I'm new to all this so I'll include the changes to the default settings I've done (hope I haven't left anything out)
* OS: Windows Server 2003 Service Pack 2 running on a dedicated server
* Domain: Let's call it example.com, http/ftp is working fine
* Firewall: Windows Firewall for the time being, port 21, 25 and 110 has been opened. Have also tried with firewall disabled on both server and client.
* SMTP and POP3 services have been installed and activated, confirmed by running telnet from the server to itself
SMTP:
* Address: Set to the server IP and port 25
* Authentication: Integrated Windows Authentication
* Delivery / Advanced / Fully-qualified domain name: example.com
* Security: added "info" (info is a user created under POP3 below)
* Domains: example.com
POP3:
* Port: 110
* SPA activated (have tried deactivated as well)
* Domain: example.com
* Mailbox: info (automaticly create user, let's assume the password was set to "infopassword")
On the clientside I've configured outlook 2003 like this:
* E-mail address: info@example.com
* User Name: info (or info@example.com depending on if SPA is active or not)
* Password: infopassword
* SPA activated (have tried deactivated as well, depending on what I set on the server)
* POP3: example.com
* SMTP: example.com
* More Settings/ Outgoing server / Use same settings as my incoming mail server
Result from "Test Account Settings...":
* Send test e-mail message: The specified server was found, but there was no response from the server.
* Find outgoing mail server (SMTP): Outlook could not connect to the outgoing mail server.
Telnet:
* Port 110 (POP3) responds normally
* Port 25: "Could not open connection to host on port 25, Connect failed
* Port 25 from the server itself: responds normally
Log:
* The only Port 25 references in the log is from the above local test, 127.0.0.1
ISP:
* I've contacted the company that host this dedicated server and made sure they aren't blocking any ports
What am I missing? FTP, HTTP, POP3 seems to work just fine but I'm getting nowhere with SMTP. Any help would be greatly appreciated cause I'm running out of ideas. Thanks.
https://www.neowin.net/forum/topic/563570-iis6-smtp-problem/
I'm no expert on smtp servers but it seems to me that your dns names aren't right. shouldn't the smtp and pop3 server be server.example.com?
do you have an Active directory? if so is example.com your external internet domain and is your windows AD domain the same?
if you have a different AD domain, myinternaldomain.local for example I would expect your smtp server to be server.myinternaldomain.local
Does not matter what he stated in the post about the name.. Clearly he can get to the server by IP or by FQDN from his client, if
Telnet:
From this I assume its his client side blocking outbound on 25 - lots of virus scanners do this by default now..
Only other thing to check - he mentions the server to itself responds.. is this to its public IP or 127.0.0.1 - maybe smtp is not listening on public IP?. But I would bet the issue is on his client side with his virus scanner blocking outbound to 25. Or -- it could be his ISP, lots of ISPs also block outbound to 25 off of their network. Trying to stop virus/trojans/worms/etc from sending email of themselves or spam, keeping people from running their own smtp servers, etc..
No
Public IP
What virus scanner are you running
None at the moment, to eliminate usual suspects
I earlier tried with an MX set to mail.example.com but it made no difference so I removed it to simplify
I'm pretty sure they don't but I'm going to check just to be sure
I've tried both with and without and it made no difference. When it is turned on it detects that telnet tries to access port 25 and asks for permission, so it's not the clientside firewall.
Can you telnet to any mail server on 25?
examples..
Trying 66.28.242.207...
Connected to mail.neowin.net (66.28.242.207).
Escape character is '^]'.
220-mail.neowin.net ESMTP
220-MagicMail Daemon with Built-In Anti-Spam
220 See http://www.linuxmagic.com for info
telnet gmail-smtp-in.l.google.com 25
Trying 72.14.205.27...
Connected to gmail-smtp-in.l.google.com (72.14.205.27).
220 mx.google.com ESMTP z21si7624232qbc
If not -- then something on your machine is blocking, or your router, or your ISP is.. If those work - then its something on server end.
