- Click refresh
- Refresh the page
- Refresh the page
- Refresh the page
Novawin
Hello guys,
I need to do my programming works for my job just after I got my new laptop with Vista from IT Fair recently.
For PHP Installation on Windows XP's IIS 5.1, it is pretty easy for me as I know how to install and configure PHP to be running on IIS 5.1 server.
So now I wanted to install and configure to run PHP on my Vista's IIS 7.0. I have followed the tutorial from IIS website closely and went through the steps starting from installing IIS to running PHP. However, at the point when I was about to add PHP ISAPI on IIS 7.0 server, I got the error as stated below. I tried to tweak some settings for adding script map but still got same error.
I have googled for help but it seemed that I can't find any solution to this. Anyone who know this?
Meanwhile, I got another problem when attempting to view a webpage after adding Virtual Directory for the name alias pointing to different folder. See the error below. I can't figure it out why kept getting the error. Even this error showed friendly message explaining what has caused this error but I still don't get it or understand this.
Anyone who can help me with PHP installation and virtual directory problem on IIS 7?
Thanks
https://www.neowin.net/forum/topic/564690-installation-and-configuration-issue-on-vistas-iis-7/Share on other sites
4 answers to this question
