FLOAT and DOUBLE in Visual Studio is garbage?
I am having some problems with visual studio 2005 professional,
I am declaring a simple double to 0.7 but in runtime it is 0.699999999999996 which is not CLOSE ENOUGH precision for my program...
I was wondering if this is a normal thing, or is it a bug in visual studio or is my hardware broken...?
check the image for a break/debug right after a few doubles have been allocated, you can see my code and you can see whats in mem..
the following info is to try and give a bigger picture of my system:
OS Name Microsoft? Windows Vista? Ultimate
Version 6.0.6000 Build 6000
System Manufacturer FUJITSU SIEMENS
System Model Amilo Mx43y Series
System Type X86-based PC
Processor Intel® Pentium® M processor 1.73GHz, 1733 Mhz, 1 Core(s), 1 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1.10C, 05/10/2005
SMBIOS Version 2.3
Hardware Abstraction Layer Version = "6.0.6000.16386"
Total Physical Memory 2,046.81 MB
Microsoft Visual Studio 2005
Version 8.0.50727.867 (vsvista.050727-8600)
Microsoft .NET Framework
Version 2.0.50727
Installed Edition: Professional
Microsoft Visual C++ 2005 77626-009-0000007-41812
Microsoft Visual Studio 2005 Professional Edition - ENU Service Pack 1 (KB926601)
Update for Microsoft Visual Studio 2005 Professional Edition - ENU (KB932232)
14 answers to this question
Uh. I recommend reading up on the differences between basic data types....If you need absolutely perfect precision, you'll need some kind of BCD-type to store your numbers.
A double is a 64bit floating point number, which is only accurate to like 18ish (Maybe less?) decimal points. After that it does some rounding.
Also, you're programming in c++, Visual Studio is just an IDE, and kinda irrelevent to the question. (Just a tip)
Anyway.
Try using a long double.
Edited by MioTheGreat
  noroom said:
That's what Double.Epsilon is for.
That's .NET.
Anyway, I take back what I said above, a long double and a double are the same thing w/ msvc++. They don't have extended precision doubles (Apparently, according to an MSDN blog, it might come in VC9).
You'll have to roll your own or find a sample online with a higher precision float, or a BCD (Which would be slower than the other option, but much more precise)
in this case I just needed 0.7 as a nice number, when I saw that it wasnt what I specified I got worried that something might be broken somewhere, I remember reading about how NASA couldnt use the pentium cpu because it calculated numbers wrong... so I got a bit worried.. ;)
thanks for your replies, it really helped me to understand how things work. still I find it weird that I specify 0.7 but it doesnt store it like that...
I tried the same thing in C# and 0.7 is 0.7 in there...
Yeah, this one is easy to understand. In fact, it happens very often and very easily if you aren't careful.
What's going on? Consider the value 0.5. That is easily representable in binary because binary uses powers of two. In the case of fractional parts, it works the same way as in decimal:
0.5 = 5 * 10^(-1) = 5 * 1/10 = 5/10 = 1/2
0.1b = 1 * 2^(-1) = 1 * 1/2 = 1/2
Obviously, for negative powers of 2, it is easy to store:
0.25 = 2 * 10^(-1) + 5 * 10^(-2) = 2/10 + 5/100 = 20/100 + 5/100 = 25/100 = 1/4
0.01b = 0 * 2^(-1) + 1 * 2^(-2) = 0 + 1 * 1/4 = 0 + 1/4 = 1/4
However, what about 1/5 (0.2)?
0.2 = 2 * 10^(-1) = 2 * 1/10 = 2/10 = 1/5
0.00110011...b = 1 * 2^(-3) + 1 * 2^(-4) + 1 * 2^(-7) + 1 * 2^(-8) + .... = 1/5
As you can see, unlike in decimal, 1/5 written in binary is a repeating value, just as 1/3 is in decimal.
You are also probably wondering how I got that value, right? The method that I've found easiest to understand is displayed here:
 x = 1 / 5
 y = "."
 x = x * 2 //multiply the value by the number base
 If x >= 1.0 Then // if x > 1 then
	 x = x - 1.0  // subtract 1 from x
	 y = y + "1" // and add a form of "carry" to a string containing the binary
 Else
	 y = y + "0"
 End If
 // repeat the multiplication process until x = 0
 // or until you find a recognizable repetition in y
 // or until the string exceeds the precision of the data type you are using
To illustrate, I'll use 1/5 as an example as if the above pseudocode actually ran and the comment about repeating the multiplication was implemented as some form of loop already:
1/5 * 2 = 2/5
2/5 >= 1 ?? No - ".0"
2/5 * 2 = 4/5
4/5 >= 1 ? No - ".00"
4/5 * 2 = 8/5
8/5 >= 1 ? Yes - ".001" // 8/5 - 1 = 3/5
3/5 * 2 = 6/5
6/5 >= 1 ? Yes - ".0011" // 6/5 - 1 = 1/5
We're back to 1/5, which is obviously where we started. Therefore, we can deduce that 1/5 repeats the 0011 combination.
Note that the above method actually works for any base:
// Hexadecimal
1/5 * 16 = 16/5
16/5 >= 1 ? Yes - ".3" // 16/5 - int(16/5) = 1/5
Since 1/5 ended up being 1/5 again, we have no need for testing again because we know that it will end up being the same thing. But why the .3 this time? Simply put, when you integer divide 16 by 5, you get 3. That value is the value that you need to use for the decimal. Also note the following way to check:
every group of 4 binary digits (bits) is equal to one hexadecimal digit (sometimes known as a hexit or hex bit). In other words, look at the following from the example:
.00110011
notice the 1s? Split them up!
. 0011 0011
Now convert them to hexadecimal:
. 3 3
The result for each group is 3, just like when the hexadecimal conversion was done.
This is probably confusing to you now. However, if you practice the conversion a couple of times, it is not that difficult.
Just remember that you check to see if the fraction is greater than or equal to 1 since the fraction should be less than 1 (if it is more than one, only part of the value is a fraction ;)). If it is greater than or equal to 1, you need to subtract the integer part of the value and you also need to add the integer part of the value to a string containing the values to give you your fraction in whatever base you want. Otherwise, you add a 0 to that string.
Try this out:
http://www.alphaworks.ibm.com/tech/decnumb...usplus/download
Or, you can switch over to Managed C++ and use the System.Decimal class which is built in. (You might be using managed c++ for all I know, I can't tell based on what you've told us)
You could also try using GMP (the GNU Multi-Precision library). There is a static build and a dynamic build for Visual C++ here as well as the source code to GMP and patches for the source code apparently -
http://cs.nyu.edu/exact/core/gmp/
Using System.Decimal would probably be the best solution since it should be a relatively similar syntax (rather than learning a whole new language by using a 3rd-party library).
    • Ashes of the Singularity II announced promising even larger battles, new faction, and more by Pulasthi Ariyasinghe A sequel for the 2016-released Ashes of the Singularity has officially been confirmed, and the original developer and publisher duo, Oxide Games and Stardock Entertainment, are back for this release too. Check out the debut trailer above. Ashes of the Singularity II is under development with a significantly expanded team compared to the original, according to today's announcement. It will be adding in a range of fresh units and gameplay systems for real-time strategy fans to dive into. More options for strategic gameplay, more intricate base building, and better enemy AI are listed as features for the new game as well. "Ten years ago, we set a new, literal benchmark for RTS games with massive battles and groundbreaking technology," said Brad Wardell, CEO of Stardock Entertainment. "With Ashes of the Singularity II, we’re raising the bar even higher, delivering strategic gameplay depth that RTS fans have always dreamed of.” The storyline of Ashes of the Singularity II will take place in 2031, with a complete single-player campaign, as well as cooperative and competitive multiplayer modes, being confirmed as features today. Moreover, a third faction is joining the fray this time, with Humans joining the fight alongside the original games' Post-Human Coalition and the Substrate. "Obviously, in the first game, the number one request was to have a human faction," adds Wardell. “Back then, we just couldn’t support having thousands of organic, walking, squishy people in the world and thus had to design in favor of machines. We’re really excited to bring the humans into the war and watch how they fare against the massive mechanical armies of the Substrate and PHC.” Ashes of the Singularity II is targeting a broad 2026 release window, with the team hoping to launch the title as the original celebrates its 10th anniversary. Its Steam store page is already up for wishlisting over here. Disclaimer: Neowin's relationship to Stardock
    • How exactly is a FREE image generation model a... Ponzi scheme?!?! I don't love all of these Gen-AI things flooding the market but there's nothing "ponzi" about it.
    • I can't decide if this is tacky or a really fun move for more casual players like myself to enjoy. I'll be curious to see how we are to fly to fictional land masses on a real globe.
      SamZrize earned a badge
      barracuda earned a badge
      189
      113
