Wifi connection failed, no Wifi found error
While using my laptop I got strange problem. Suddenly I'm loosing my Wifi connection and when I try to look for any wireless networks around it says that no networks were found - that's not true, all neighbours and mine are working fine (like 8 of them total). Only restarting computer helps.
I found those details inside event manger, this two events appear exacly same time to a second:
Event 11002:
Wireless network association failed.
Network Adapter: Atheros AR5007UG Wireless Network Adapter
Interface GUID: {3E2236AC-16C6-4222-A0EA-F3075525D885}
Local MAC Address: <ereased for forum>
Network SSID: xxxxx
BSS Type: Infrastructure
Failure Reason: Driver disconnected while associating.
Reason Code: 229378
and Event 8002:
WLAN AutoConfig service failed to connect to a wireless network.
Connection Mode: Automatic connection with a profile
Profile Name: xxxxx
SSID: xxxxx
Failure Reason:Driver disconnected while associating.
anyone have idea what cause the problem (I bet it's network drivers but those are the best I could find), or any possible fix?
Thank you for any help in advance ...
