jallaman Posted August 9, 2007 Share Posted August 9, 2007 A little while ago i installed autopatcher and discoverd that ie did not work after that. the problem is when i type in an url an error message appears it says "the requested lookup key was not found in any active activation context" however if i set a url as homepage it can load that at startup. Link to comment https://www.neowin.net/forum/topic/579750-ie-problem/ Share on other sites More sharing options...
PsiMoon314 Posted August 10, 2007 Share Posted August 10, 2007 Hi, I think there is a good possibility that your installation of IE7 has failed. You might want to uninstall IE7 via Add / Remove programs, reboot and then reinstall it once more. Kind Regards Simon Link to comment https://www.neowin.net/forum/topic/579750-ie-problem/#findComment-588769950 Share on other sites More sharing options...
